i don't post much but
Old Nov 11, 2002 | 03:11 PM
ice775899's Avatar
i work for a chrysler /dodge dealership and it could be done but the only thing he didn't think of is that intrepids are already rwd and there is no way he could get a prowler tranny so cheap
Old Nov 11, 2002 | 04:46 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
The only RWD intrepid is the ones on the NASCAR track. Again
[20] NO PICS =NO PROOF[/20]
Old Nov 11, 2002 | 04:47 PM
MDv6man's Avatar
Car: 1983, 1986
NO PICS =NO PROOF
Old Nov 11, 2002 | 05:22 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Re: i don't post much but
Actually I have a question about this.
I have only seen pictures of Intrepid engines. But what I was wondering is did dodge mount the FWD intrepid engines North--south instead of east--west? cause in the pictures they sure look that way.
Old Nov 11, 2002 | 08:04 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Re: Re: i don't post much but
Yes, the engines do sit North-South, BUT they are still mated to a transaxle and are FRONT WHEEL DRIVE.
Caddilac started doing that garbage back around the '70's.
Old Nov 11, 2002 | 08:19 PM
Joe_L's Avatar
Car: 1995 Z28
Thanks,
I have been thinking there were mounted north south. Easier to work on, but probably a pain the *** cause they are FWD still.
I never actually saw one up close, so I have been wondering about this for some time.
Old Nov 11, 2002 | 08:24 PM
Engine: LH0 3.1L
You'd think they'd be easier to work on......... but every Chrysler i've seen with that setup is crammed in. On some cars, the gap between the front of the engine and the radiator is about ONE INCH. How in the frick are you supposed to change ANYTHING on the front of the motor???
Old Nov 11, 2002 | 08:31 PM
Joe_L's Avatar
Car: 1995 Z28
Sounds like they hired a honda engineer.
A friend bought a 87 Pre lude, thought he would fix it up.
Ended up selling it cause changing the alternator at a garage was going to cost more then the car was worth.
Alternator is under the motor. I mean what in the heck was honda thinking.
Old Nov 12, 2002 | 08:11 PM
devianb's Avatar
You have to pull engine accessories off and such, which adds to the repair bill.
Old Nov 12, 2002 | 08:18 PM
Engine: LH0 3.1L
Same with the old DOHC 3.4L. I'm lucky enough to not have had to do one yet (knock on wood) but you have to unbolt the engine cradle to get the alternator out. NOT FUN.
BTW, since the alternator was mounted at the bottom behind the motor where heat is aplenty, GM installed a vent duct down to the back of the alt to cool it down.
Old Nov 12, 2002 | 09:03 PM
Joe_L's Avatar
Car: 1995 Z28
I hope when I finish my engineering program, that I don't do stupid stuff like this. I probably will, but I hope I see the little things that count.
hahaha little vent down back to cool the alternator, more work probably went into putting it down under the motor then putting up top where it should be.
Old Nov 14, 2002 | 05:09 AM
I Cant Drive 55's Avatar
The SAAB 99 and 900 series are also mounted north to south FWD . they are actually pretty easy to work on. The SAAB 9000 went EAST to WEST and they are a pain to work on . Go figure.
Old Nov 14, 2002 | 07:08 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The Intrepid is set up for rwd but it was never used. the body is even stamped for rwd, tranny hump, drive shaft vally. Guy I knew wanted to put a T-56 in his Intrepid why the tranny went but he could not find any way to get it done. This is a guy who has dual 5spd trannys end to end with his own home made adapter and that give his truck a super wide range of gears. If there was any way possiable it would have already been done.
for the cost of parts id go the same big v6 route but stay chevy with the 4.3, single or twin turbo, 4.3 was in monte carlo and chevy truck 2wd and 4x4 so lots of parts, stick, auto, all wheel drive
Old Nov 14, 2002 | 04:32 PM
Heres an interesting note on the Intrepid.
They are planning on making a RWD Intrepid I think in 2004 , so they can compete with the Ford crown vic as police cruisers.
Old Nov 14, 2002 | 07:22 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Re: Re: Re: i don't post much but
yeah, that doesnt do anything but **** the **** out of us mechanics
btw, dan- how are you doing as a mechanic?
my service manager CLAIMS i cracked an oil pan on a FORD (i work at a GM dealer) and thus he sent me back to doing PDI's and wants me terminated
Old Nov 14, 2002 | 07:46 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Actually I believe it will come out as a Charger
I think they are eliminating the intrepid line...
Old Nov 15, 2002 | 12:25 AM
Engine: LH0 3.1L
Re: Re: Re: Re: i don't post much but
Check your Pee Emm's.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
