will 3.4 heads fit on 3.1/will 3.4 cam fit 3.1
Old Nov 17, 2002 | 09:32 PM
Xceleratemaro's Avatar
I have a 3.1 Camaro and I wanted to do something to make it a little faster and i was reading that 3.4 heads have more meat on them to port/polish and this could be a good junkyard head to get to play with. Also where do i find a cam to go into my motor, how much? also i here there is a guy on here makeing custom hedders, and i was wondering if that would work with my electronic egr. i have a 90 rs and i plan to put a air box on it that came on the 2.8 cars that go between the bumper and radiator the air box has a mass airflow sensor on it and my car dose not have one on it to the best of my knowledge what do i do?
Old Nov 17, 2002 | 10:22 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
1. Welcome to the board!
2. 2.8/3.1/3.4 are the same head.
3. any 3.4 cam can be used in your block. replace springs when doing so.
4. (in Yoda voice) Use the search, Luke, and all your answers will come
Old Nov 18, 2002 | 09:16 AM
KED85's Avatar
Not correct, see this answer in other thread, same title.
Is this a Twlight Zone Episode?
Old Nov 18, 2002 | 11:48 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
*twilight zone music plays*
Actually took me a minute to figure out it was two posts.
Old Nov 18, 2002 | 06:21 PM
sorry about having two posts opps!!!!
anywho im planing on buying a set of junkyard heads and pocket porting and polishing i would like to also put a cam in my car
im debating on a crane cam of 198-204 401-423 or 204-214 423-423 i would like to keep the stock valve springs and rocker arms
which cam should i go with?
also dose any one have a z-28 front bumper for a 89-92 camaro
and a hood, Someone hit and ran in a wallmart parking lot and i would like to get my car looking good agian so if you are looking to sell any please post me Greenvill SC
Old Nov 18, 2002 | 06:38 PM
KED85's Avatar
Serious
Drive your 2.8 into the ground
Locate a 3.4 & swap in have fun for cheap & way better use of effort.
Again
Ebay is your new wrecking yard.
Everyday punch 3.4 60* & see what happens.
One guy got his for $500 (w/out delivery charges) thru ebay.
Last guy was $910 including delivery (also ebay)
Again better use of our effort.
Cause if ya swap in the cams & heads, you'll be swapping mills rather soon after anyway.
These little engine's at high milage, see end kinda quick soon after you swap on heads & such.
Old Nov 18, 2002 | 07:20 PM
i got 181000 miles on her now orginal 3.1
thanks for the advice
Old Nov 18, 2002 | 08:56 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I am the last one who recived one. 910-920 to the docks in my town. Engine looks good so far, just needs the recommened timing chain.
I belive you will recieve better results doing the full swap, rather then just cam and heads
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
anesthes
Aug 8, 2015 09:37 PM
