gas mileage
Old Dec 5, 2002 | 11:23 AM
confucius101's Avatar
gas mileage
i have a 91 3.1l bird
i'm get about 150 miles out of a full tack
does this sound about right?
and yes before you ask i just did a complete
"tomp" tune up not to long ago
Old Dec 5, 2002 | 11:55 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Not really, others will say they get at least 20 mpg. But don't sweat, my 2.8 got about that. Probably because of the exhaust leak at the manifold. Check all your vacuum lines too.
Old Dec 5, 2002 | 11:58 AM
ya thats what i thought........
the funny thing is a almost 90% positive
that i got better mileage B 4 the tune up
Old Dec 5, 2002 | 03:05 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Man, your car eats more gas than my friends 95 Z28! There is something terribly wrong if you're getting that bad of gas mileage. I get about 20- 22 around town and about 250 or more to a tank. Maybe you just have a MAJOR lead foot? I don't know....
Old Dec 5, 2002 | 03:10 PM
PeNZ's Avatar
I get about 150 too, but I have a heavy foot, and im always have it mashed
Old Dec 5, 2002 | 04:33 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
I get around 400KM's to a tank of Gas. Thats about 22mpg city with a heavy foot.
Old Dec 5, 2002 | 05:22 PM
Camar_Hunter_c's Avatar
running these small tires, which makes my gear ratio 3.80 and change, I get 280 +/- per tank. So when i get back to stock size SOON I will be back to 330+ per tank. I basically have 16% +/- undersized tires right now.
Old Dec 5, 2002 | 07:47 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
mine gets around 250-300.
When I had to take it up north for a few days, averaged 17.9 in town, in below freezing weather.
Old Dec 6, 2002 | 08:44 AM
wow thanks for all the input guy's
Old Dec 6, 2002 | 09:25 AM
1991rsblue's Avatar
i usually fill up once a week with 89 octane and usually get 25-300 miles out of it mostly around town and once in a while on the highway. 150 is crapy. you must must must check your wires and fuel economy. something you did when you made your tune up went wrong to 150 mpg. what plugs and wires did you use. did you make your own wires?? maybe you have a weak connection or something. I personally would check the whole car over and make sure everything was put togeter right.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Glowsock
Sep 11, 2015 11:09 PM
