i shoot out black smoke at 5 grand. anyone have any ideas of what the cause is?
Old Dec 9, 2002 | 11:00 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
when i floor my 3.1, it shoots a cloud of black smoke out the back at around 5000 rpm. i dont think its anything bad, just curious about what is causing it. thanks for any replies
Old Dec 9, 2002 | 11:20 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
your engine is old and dirty lots of carbon buildup to get rid of running high octane gasoline and running the **** out of it usually cleans out the combustion chamber real good don't for get to clean the throttle body and fuel system too
Old Dec 9, 2002 | 11:39 PM
AFreaknGoodTme's Avatar
Black smoke is generally a result of running rich. This can be caused by too much fuel pressure or any # of bad ignition/electronic components
Old Dec 10, 2002 | 12:34 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
thanks for the quick replies!
once i'm done with finals and winter vacation comes around, i was thinking about replacing some of the ignition stuff, and seeing if i could get anything from it. any suggestions?
Old Dec 10, 2002 | 03:25 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
While your at it put in a new Oxygen sensor they are like 25 bucks but it will help the car run correctley if it runs lean or rich it will tell the computer how to adjust it so it runs clean.
Old Dec 10, 2002 | 12:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: i shoot out black smoke at 5 grand. anyone have any ideas of what the cause is?
Are you rolling into the throttle or just womping it to the floor?
Rolling into the throttle can cause an excessive rich mixture once PE becomes active.
RBob.
Old Dec 10, 2002 | 12:28 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Friend of mine's Saturn does it too. Always wondered what causes it...seems to be an extremely common problem among Saturns.
Old Dec 10, 2002 | 07:25 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
its when i "womp it to the floor"
Old Dec 11, 2002 | 04:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You're revving it up to 5 grand in neutral? Seems like a good way to throw a rod...
Old Dec 11, 2002 | 05:37 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
no man, i never said that.
Frozer!!!
Jan 19, 2024 04:55 PM
diana227vegas
Jul 8, 2016 12:27 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
spaigo
Aug 21, 2015 07:46 PM
squiggy2
Aug 9, 2015 09:30 PM
