Fuel pressure regulators
Old Dec 10, 2002 | 12:33 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I've heard adding an adjustable fuel pressure regulator and cranking up fuel pressure in larger engines can add a lot of cheap horsepower easily... So my question is, will increasing fuel pressure a little in our cars add power? If so, what is our stock fuel pressure # and what would you recommend running? Thanks
Old Dec 10, 2002 | 01:23 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Never heard that about cranking it up.
These cars run between 41-47 PSI
Old Dec 10, 2002 | 06:53 PM
Nixon1's Avatar
It was in an issue of Hot Rod..they raised fuel pressure on what I think was a 350...I think they raised it from 45 to like 50, and 55, and 60, and gave the dyno numbers.. Power curves were modified slightly, but at the peak it gained like OVER 20 hp just from bringing the fuel pressure up. Not sure which number that was for but I want to say 60. It just robbed a tad of low end power but added a LOT of top end.
Old Dec 10, 2002 | 09:04 PM
AFreaknGoodTme's Avatar
Ive always been told 35-42psi ?
Old Dec 10, 2002 | 09:15 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Key On, Engine Off: 40-47 psi for 2 seconds
Key On, Engine Running: 3-10 psi lower than KOEO reading
Old Dec 11, 2002 | 07:03 AM
Dale's Avatar
Engine: 350 S-TPI
My repair book says same thing as cali just posted.
Plus I tested it once when having probs with the car. Tested at 45 with key on, dropped 4 when started.
Old Dec 11, 2002 | 08:24 AM
mvftw's Avatar
Also CaliCamaroRS is right, but the fuel gauge has to hold the pressure when the key is off, if it drops quickly it means a return leak somewhere. And that will cause your car to run like crap and that's a hard one to find.
Old Dec 11, 2002 | 09:07 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
without a large amount of engine modifications (read: hard parts, heads, manifold) an AFPR is un-needed
Old Dec 11, 2002 | 04:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree with Teal... if you did a ton of head porting and lost performance, you'd probably need to increase the fuel pressure. You might just want to send your injectors (or a junkyard set) out to http://www.cruzinperformance.com and have Rich clean & flow-test them. It made a big improvement in the way my car felt!
Old Dec 11, 2002 | 05:25 PM
Nixon1's Avatar
Yeah? That could be my problem. I've been replacing things one by one and I'm pretty much at the end of my list but the car still has a rapid vibration/shimmy to it. It's got new plugs, wires, cap, and rotor...and the vacuum lines all check out.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
