3.1 chip
Old Dec 13, 2002 | 09:48 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
3.1 chip
i would greatly appreciate any information that anyone could give on burning chips. i've read most of the 'sticky' post on this subject but i'm still pretty much lost. I have a 91 RS 3.1L. I am putting a Hi Po engine in it and am going to try to run the TPI setup but am assuming that it will not run too good with stock chip. Please help! can you burn the stock chip or not? Thanks in advance for any help!
Old Dec 14, 2002 | 07:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 3.1 chip
I'd suggest going over to the DIY_PROM board and just reading though the posts for a while. There is also a sticky at the top of that board that will answer a lot of questions.
To get you started the ECM you have is the 1227730 or '730 for short. Has a removable calpack that includes the EPROM. Can reburn that EPROM although I don't suggest it.
When it comes time to tune Tunercat has the code definition file for that mask ($88).
RBob.
Old Dec 14, 2002 | 07:34 AM
Car: 91 Camaro
thanks for the info RBob!
Old Dec 15, 2002 | 05:09 PM
Camar_Hunter_c's Avatar
or do it the old fashioned way...
data record and reveiw. You can find holes in the BIN/Program easily.
Yes your reprogramming from scratch, dealing with teh stock bin, but hell thats what has to be done wayway.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
