Lil help here
Old Dec 14, 2002 | 01:21 PM
Ovrclck350's Avatar
Lil help here
Lately sometimes when i go start my car, it almost acts like it's running on 5 cylinders for a few minutes, then all of a sudden it runs fine. I was thinking maybe i had a loose plug wire, but I checked all them. Only other options is something else in the ignition, or maybe my cat is bad but for some reason lets enough pressure through once it warms up a lil bit. After it starts running right, it runs perfect.
Old Dec 14, 2002 | 02:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
next time it does that, turn it off and back on. easier in a stick when you can just keep rollin but.
Mine will do that now and then, starts up fine but soon as I get going it was under powered. push inthe clutch, tunr it off, tunr it back on, pop the clutch and she fires up and runs like normal.
Gotta be a sensor or the computer, like a part of it dont start right, shut it off and it resets it. ??? who knows, I would dig more if it didnt run so good.
Old Dec 14, 2002 | 03:07 PM
Ovrclck350's Avatar
Done the whole restart thing. Still does it. I can tell as soon as I start it up if it's doing it or not. It's not a problem that just happens when I start going. Most times, it'll quit as soon as I start going actually.
Old Dec 14, 2002 | 03:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
could be plugs??? long shot though.
long time ago I had an 79 camaro 305 2bb.
when ideling or in the drive through. it would do that, get going and and it was fine. did that for a month and then finally would not even start.
changed everything in electrical system, bought some 89 cent champion plugs as a last ditch effort and it ran. wasnt even close to time for a change, plugs looked clean and great but somehow they were bad.
----- only reason I bring it up cause my 86 did that.
started acting nuts like a bad fuel pump, I changed and checkked everything unde rthe sun, plugs n wire fixed everything.
Seams
like these Gm cars can eat plugs but show no sign of wear.
Old Dec 14, 2002 | 04:08 PM
Ovrclck350's Avatar
I was thinking maybe plugs too....I *THINK* they have about 25K or so on them.
Old Dec 14, 2002 | 04:21 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Injectors tend to stick when cold rather than hot.
You can do an injector balance test with an injector tester(not that expensive and it's a good tool) and a fuel pressure gauge.....unfortunately you have to pull the upper plenum though.
Old Dec 15, 2002 | 07:55 AM
Vampele88's Avatar
Mine did same thing
My 88 FB did the exact same thing for awhile and last week with some help and suggestions from the board I ended up replacing the coil,plugs,checking injectors,vaccuum etc and guess what the plug wires were on good looked good etc but were bad, it would run fine fore a sec then miss real bad, run fine, bad back and forth and all it needed was a new set of plug wires, now she purrs like she was new, although I probably wasted about 100$ extra in gas while she was running like that, LOL, Oh and the stock OEM set only cost me 20$ or 25$ for a pair of Bosch,s in different colors.
Old Dec 15, 2002 | 11:43 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Sounds like an injector problem to me. Anyway I would start the car and start pulling spark plug wires until I found the bad hole. Its much easyer to work on it when you know which cylinder isnt lighting.
project89
Sep 24, 2015 06:38 AM
Racerx974
Sep 19, 2015 10:16 AM
383cam
Sep 9, 2015 06:01 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Stell1579
Jan 7, 2001 02:31 AM
