3.1L timing help
Old Dec 15, 2002 | 03:28 PM
92RSMuscle's Avatar
3.1L timing help
whats stock timing on a 3.1?
i have a light, but how do i adjust it?
and whats the best to adjust it to?
Old Dec 15, 2002 | 03:44 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Stock is 10* advanced but most people set it to 12*.
To set timing you need to disconnect the EST wire. It's brown with a black stripe and the connector is near the passenger strut tower. This will put the engine in base timing. Then loosen the distributor and spin the cap until you get the right timing.Then tighten the distributor, reconnect the EST, and then cycle the key off for a few seconds. You will set a code while doing this however.
Old Dec 15, 2002 | 04:14 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Hey Cali, where is the distributor holddown, and is it a nut, or a screw or what? I've tried to look around there but I can't get my fat head back to see past the cap and cap holddown screws.
Old Dec 15, 2002 | 05:10 PM
Camar_Hunter_c's Avatar
passanger side engine.
Distributor.
Bright light pointed at base of distributor.
do you see the 15MM bolt head yet?
if not get 2 big cans of brake cleaner. Spray, Research.
Old Dec 15, 2002 | 08:48 PM
Nixon1's Avatar
Thanks man...I'll check tomorrow afternoon, when it's not pitch black and 40 degrees out.
Old Dec 16, 2002 | 03:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: 3.1L timing help
Were you talking about adjusting timing on the Car, or adjusting the timing on the light (for a dial-back timing light)? I believe on a dial-back light, you set the **** for 0 degrees advance. I have a regular timing gun, never used a dial-back model, so I can't help more...
Old Dec 16, 2002 | 03:26 PM
Nixon1's Avatar
What the hell is a dial back light anyways......lol..
Old Dec 17, 2002 | 10:56 AM
92RSMuscle's Avatar
i have a standard light - no dial
jhawkeye
May 25, 2022 06:33 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
92projectcamaro
Aug 6, 2015 01:20 PM
