Well... it [i]wasn't[/i] the tranny (yet)
Old Dec 30, 2002 | 10:08 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Well after sitting since the 20th, I finally had enough time to look into the 83's shifting problem. I adjusted the TV cable last night, and managed to break off the second tab that hols it in the metal bracket (@#$%). So I got creative...
Initially I tried to fab up a piece of metal to hold the adjuster in place. However, the metal was too soft and kept breaking SOOOO I took three rubber bands. Two I wrapped around the metal bracket and the third one was woven around the distributor cap towers to assist in it keeping in place.
Took it out for a test drive -- nice smooth shifting, no slipping, running quite well.
I'm not going to drive it regularly in its current state as I don't want the engine heat to kill the rubber bands while on the highway (can you say over rev?). Plus the tranny will be going to get rebuilt in a couple of days and I'll have them but a new cable in.
Old Dec 30, 2002 | 12:08 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Mind telling me how you got the thing out? Did you take the bracket bolt off, and then..what...use a screwdriver or something to press down on the plastic piece's tabs? I need to adjust mine but can't get access to it because of that damn bracket.....but I'm afraid to mess with it now!
Old Dec 30, 2002 | 12:23 PM
MDv6man's Avatar
Car: 1983, 1986
Well I was working on the carbed v6 but I have adjusted it on my 86. Basically what you said is correct -- Take a screwdriver and push the tabs down. One broke off the last time I had the tranny being sealed at the shop. The second one broke last night.
Don't feel bad -- On the 82-84 Camaros, its located at the back of the passenger side valve cover surrounded by a bracket. PITA to get to!
dps8315
Jan 8, 2002 11:08 PM
Dave M
Oct 21, 2001 04:41 AM
Dave M
Oct 19, 2001 07:59 PM
CD MaroMan 91
Aug 31, 2001 05:40 PM
bhaas
Jul 12, 2001 03:40 PM
