Emissions Legal Cam?!?
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
Ok...so there i was reading through my JEGS catalog...and i'm in the cam and lifters section...i see the cam that crane makes for our cars...and there is a big logo over it saying that it is 50 state emission legal...am i going crazy or is this for real...
Car: 1986 Firebird
Engine: 2.8 V6
Nope, unfortunately, you're going crazy.
The emissions legal badge refers to the other cams around that one. I assume it's in a list with v8 cams? The Crane cam isn't emissions legal, it doesn't have an EO (executive order) number. That's why I've held off on a cam for so long; in NJ, we have a strict emissions test, done on a dyno. Supposedly though (and I'll find this out when I rebuild the 2.8), if a cam for a v6 has similar characteristics (lobe sep, max lift, etc) to that of an emissions legal V8 cam, then the V6 one will also be emissions legal. A lot of red tape and $$ is associated with getting an EO number, so the cam might pass emissions, but Crane didn't want to go through all the headaches for a handful of v6 owners.
The emissions legal badge refers to the other cams around that one. I assume it's in a list with v8 cams? The Crane cam isn't emissions legal, it doesn't have an EO (executive order) number. That's why I've held off on a cam for so long; in NJ, we have a strict emissions test, done on a dyno. Supposedly though (and I'll find this out when I rebuild the 2.8), if a cam for a v6 has similar characteristics (lobe sep, max lift, etc) to that of an emissions legal V8 cam, then the V6 one will also be emissions legal. A lot of red tape and $$ is associated with getting an EO number, so the cam might pass emissions, but Crane didn't want to go through all the headaches for a handful of v6 owners. In my summit magazine , it says its emissions legal
.....BUT ....its right along with all the other camshafts under it ....That's mis-leading isn't it Tom ! It's a good thing I did not order one like I wanted to awhile back . I would have been raising some hell with Summit when my car did not pass the sniffer !!!! All this time I have been thinking it was emissions legal !
.....BUT ....its right along with all the other camshafts under it ....That's mis-leading isn't it Tom ! It's a good thing I did not order one like I wanted to awhile back . I would have been raising some hell with Summit when my car did not pass the sniffer !!!! All this time I have been thinking it was emissions legal ! Thread Starter
Car: 1985 Firebird
Engine: 2.8 V-6
yea...for a moment i was like wow...its emissions legal...this will be cool...i guess i wasn't going crazy...oh well...i'm sure sooner or later it will happen...here in RI there is the possibility of them changing emissions laws where vehicles 85 and earlier won't have to pass emissions...that would be a godsend over here...however i do have a buddy who is certified to do state inspections...maybe he can hook up one of them new hondas on the dyno for the sniff sniff test...we'll see...i mean...that cam will complete my future 3.4 project with some of the other goodies i will purchase...we'll have to just wait and see...thanks for clearing that up for me guyz...i know i'm a little crazy...but not stupid or antyhing...whooh...i thought there was something wrong with me...lata...
Car: 1986 Firebird
Engine: 2.8 V6
I actually went and looked the EO number up at CARB's website (california air resources board), and it listed all the v8 cams in that section, but didn't mention the v6 cams. But supposedly since the cam has close to the same profile as the v8 cams, and the v8 cams are smog legal, then that means the v6 cams will probably pass the smog test. Key word is "probably", but at least it's somewhat of an answer.
It would also depend on how close your particular car is to failing the smog test. If your car passes emissions with really low CO and HC counts (like mine does
), the cam probably wouldn't make you fail. However, if your car barely passes as is, it would be pretty safe to assume that the newer, more aggressive cam would push you into the 'fail' category. And just for the sake of venting, it really pisses me off that a few zealots on the west coast (read: CARB) is ruining all our motoring fun. I'm all for clean cars, but stupid red-tape bureaucracies like CARB are going about things the wrong way. At least the emissions shop where I live doesn't care what's done to your car, as long as it passes. The only reason the guy popped my hood was to put the inductive pickup on my motor so he could monitor engine speed. In theory, you could have a totally built motor with NO emissions equipment, and as long as emissions were at acceptable levels, here's your sticker, off you go!
), the cam probably wouldn't make you fail. However, if your car barely passes as is, it would be pretty safe to assume that the newer, more aggressive cam would push you into the 'fail' category. And just for the sake of venting, it really pisses me off that a few zealots on the west coast (read: CARB) is ruining all our motoring fun. I'm all for clean cars, but stupid red-tape bureaucracies like CARB are going about things the wrong way. At least the emissions shop where I live doesn't care what's done to your car, as long as it passes. The only reason the guy popped my hood was to put the inductive pickup on my motor so he could monitor engine speed. In theory, you could have a totally built motor with NO emissions equipment, and as long as emissions were at acceptable levels, here's your sticker, off you go! Trending Topics
Car: 1985 Firebird
Engine: 2.8 V-6
my car passes with almost nothing on those readings...my car is really clean...i forget what the limit is on my car...but the readings is so low...so maybe it won't make much difference...but however...when i put the 3.4 in i won't know how well it passes emissions until i get to it...so we'll see until then...thanx for the responses guyz...
Car: 1986 Firebird
Engine: 2.8 V6
Did you pass emissions tests with that blue racer cam? Your picture says you're in New York... what kind of emissions test is up there?
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
jeez, with that many mods to your engine, i'd be suprised if you passed really easily.
it seems like you've totally re done your engine to be a screamer, and i wouldnt think thats emissions-testing friendly, but my hats off to you for pulling it off!
Car: 1986 Firebird
Engine: not stock 2.8
I have the blue racer in my car aswell, it's a great cam. I kind of doubt you will pass strict emissions with it tho. I'm lucky that I don't have to pass ANY emissions where I live... the car's running with no cat, and a disabled smog pump to boot. You can just smell the raw gas, kinda like an old muscle car when you let off the gas at a stop after giving it.
how about this comp cam this is what they recomended for my2.8 i know nothing about cams does this sound good?
PART NUMBER 16-232-4
ENGINE CHEV. 60 DEGREE V-6
GRIND # CV6E 252H-10
DESCRIPTION HIGH ENERGY
INT EXH
VALVE ADJUSTMENT HYD HYD0
GROSS VALVE LIFT .425 .425
DURATION AT
.006 TAPPET LIFT 252 252
VALVE TIMING OPEN CLOSE
AT .006 INT 20 52
EXH 60 12
THESE SPECS ARE FOR CAM INSTALLED
AT 106 INT C/L
INT EXH
DUR AT .050 206 206
LOBE LIFT .2835 .2835
LOBE SEPARATION 110.0 INT MASTER ID 252H-4
ADVANCE 4 EXH MASTER ID 252H-4
RECOMMENDED CC VALVE SPRINGS 980-12
INT EXH
DURATION AT
AT .006 INT 20 52
EXH 60 12
AT 106 INT C/L
INT EXH
DUR AT .050 206 206
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
