somehting i saw
Old Feb 8, 2003 | 12:37 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
somehting i saw
ok well my mechanics teacher (hes an ideot) put his air filter lid on upside down...how much does that effect anything, if anything at all.
Old Feb 8, 2003 | 05:16 PM
David Blalock's Avatar
Whoa... might wanna keep that guy off the heavy drugs. I'd think unfiltered air could get in since it may not seal correctly.
David
Old Feb 8, 2003 | 05:36 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
My friend's dad does this too on carbureted cars..it's an old trick apparently, I've heard it several times before. Not so much for the extra air flow, which is very minimal, but supposedly it makes the engine louder/sound better...
Old Feb 8, 2003 | 06:29 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Supposibly it helps it breath better. I does make exhaust deeper, and tends to use "tad" bit more gas.
Old Feb 8, 2003 | 06:39 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
But you risk sucking in dirt and debrits into the motor? As long as the top seals then you dont have to worry.
Old Feb 8, 2003 | 07:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Dirt and dust oh no.
It just like running an open element but on a carbed car, it get better flow but if not adjusted right it can run lean.
It does and will seal just fine upside down but you might get too much air. it was designed to suck air through the snout, more air is better but only if you tune the carb for it.
and it does make the car sound cooler as you can now hear the engine and them 4 barrels when they kick in.....
Old Feb 8, 2003 | 09:32 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
They use to do that to all of the cop cars back in the 70's. It give a little better flow. This was long before everyone got into cold air intakes. Engine compartments were more roomy and the air was not as hot as it is in newer cars.
Old Feb 9, 2003 | 12:00 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Gumby, you don't have to worry about it getting too much air. the motor pulls in whatever air it needs, more filter exposed does not mean that more air WILL go into the motor it does mean that more CAN go in (if the motor needs it).
dennisbernal91z
Dec 16, 2005 06:42 PM
dennisbernal91z
Nov 24, 2005 07:29 PM
dennisbernal91z
Nov 14, 2005 12:48 PM
SlowMaro
Aug 5, 2003 05:24 AM
Mshrmhd
Mar 16, 2003 01:14 PM
