Unlocking the doors...
Old Jul 17, 2004 | 11:27 PM
  #51
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I can get into just about any 3rd gen F-body in less than 1 min. Pull the window out enough to slip my arm in-between the window and the A-pillar reach down and unlock the door then open, bam.
I've locked my keys in more than I can count and get in this way every time.
Old Jul 17, 2004 | 11:38 PM
  #52
Klortho's Avatar
Car: 1987 GTA
blah, double post
Old Jul 18, 2004 | 12:25 AM
  #53
duranged's Avatar
Car: '88 firebird/'98 durango
Engine: 2.8v6/5.2v8
yeah,another think is condensation and moisture casue the solenoids to trip the relays for the door lock, i went throught that with my 88 a few times, until i just pulled the relays out, they r located behind the kick panel, at least on the 88 firebirds they r , i am not sure about other years or the camaro,
Old Jul 18, 2004 | 12:27 AM
  #54
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
First off, DON'T LOCK YOUR KEYS IN YOUR CAR!
Second, my brother once locked my keys in my car and used my dad's '88 chev pickup keys to unlock it.
If you want security:
1. Don't leave stuff in your car. Someone broke into my car a few months ago (screwdriver in lock I presume, but the lock still works) and I can only assume they were looking for my stereo faceplate in the console because they didn't end up stealing anything (faceplate was in my apartment as always). They left my $100 sunglasses and all my tools.
2. If you plan on leaving your car parked somewhere for a while, take a part of your car with you. I like to take my coil to distributor wire. It's easy to remove/install, and who's going to have a spare one when they try to take the car?
3. Maybe some might disagree, but I like those club-like things that go between your clutch or brake pedal and the floor... although I don't have one.
Old Jul 18, 2004 | 01:21 AM
  #55
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
I locked my keys in my car once and couldn't get it with a coat hanger so I tried a very small flat head screwdriver in the key hole and with no problem at all I unlocked the door as if it were the key.
One time in winter my doors froze shut and I had to pop the hatch and go through that way. And I ain't a small guy, 6'6" 290lbs
Old Jul 18, 2004 | 01:23 AM
  #56
That's funny! I had the same problem. I could unlock the door, but I couldn't break the ice on the seal without ripping the door handle off. But I could get a good grip on the hatch, so I went in that way.
Old Jul 18, 2004 | 10:25 AM
  #57
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Wll I have/use a "low-buck_ fix for not getting out of the car without the keys.
I have a short chain, about 30" with a snap "D" ring that I hook to my pants loop.
You can drive, and move around in the car, but try to get out with keys in ignition, and you suddenly stop about 3" above the seat. And if they are out of the ignition, they get dragged out with you.
They can also serve as a make shift weapon if needed.
Old Jul 18, 2004 | 02:53 PM
  #58
Some Camaros come with this new technology called a buzzer that signifies the keys are still in the ignition.
Old Jul 18, 2004 | 03:52 PM
  #59
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My buzzer switch hadn't worked for years; when I pulled the ignition lock to replace the cylinder, I found out why- the buzzer's contact switch had cracked. So I put the broken buzzer switch back in.
Just keep a door key in your wallet and you'll all be okay. But I do like V6sucker's solution, too! (Especially about the weapon part )
Fronzizzle
Mar 18, 2019 08:29 PM
Roblyons
Sep 12, 2015 10:29 PM
NWAsonoma
Aug 18, 2015 05:45 PM
John Millican
Sep 10, 2001 10:43 PM
jm91rs
Jun 29, 2001 12:16 PM
