How do I unstuck my fuel filter?
Old Feb 17, 2003 | 05:23 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Ok I pulled the fuse, cranked it for a few seconts, then tried to get if off. Wouldn't budge, so I sprayed some WD40 on it every hour for 8 hours, still wouldn't move the next day still stuck. I know thier has to be somthing better than WD40, anyone know what its called and where to get it? Thanks.
Old Feb 17, 2003 | 06:33 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
You need two open end wrenches for the job. Put one on the filter and hold it in place while you untighten the fitting that goes into the filter. Or get some penatrating spray to put on it.
Old Feb 17, 2003 | 06:51 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Ya, I know the wrench thing, anyone know the sizes offhand BTW, or atleast metric or SAE? Just wondering if anyone knows any really good brand of penetrating lubricat.
Old Feb 17, 2003 | 07:07 PM
Car: 85 Camaro SC
Engine: V6
I think they were 10,12,14 mm. Mine came right off with no problems. Hey put your old filter on a weight scale when you have it off. Mine weighed almost a pound.
Old Feb 17, 2003 | 07:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Good luck...
I found it was just easier too cut it out. get a few inches of some stainless covered hose and some double clamps. right next too the filter for our car on the shelf is one just like it with nippled ends for a hose instead of fitting. Im sure they sell more of the nippled ones.
Old Feb 17, 2003 | 09:00 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Liquid Wrench, or PB Blast are probably the best penetrating oils we can get @ the AZ & stuff. remembering what my fuel filter looked like from when I redid my rear brake hose, I moght do the Gumby thing
Old Feb 17, 2003 | 09:07 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Ill try some of that stuff I guess, but I have no garage and their is 19in of snow on the ground, so I guess that and my tranny fluid have to wait.
Old Feb 19, 2003 | 08:55 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I love liquid wrench! Tried PB blaster, never seemed to work better than liquid wrench, I'd place them about the same level. But yeah, WD40 is mainly a lubricant (water-displacement #40), not too good for breaking bolts free with.
Old Feb 19, 2003 | 08:14 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
ive been wondering this for a while, where is the fuel filter on a 89 camaro with a 2.8mpfi v6?
Old Feb 19, 2003 | 08:21 PM
Engine: 5.7 / 7.4
about 6-12" infront of the axle underneath, close to centerline of car.
Old Feb 19, 2003 | 08:39 PM
Transmission: autos
u sure i had it on a lift the other day and didnt see it
Old Feb 19, 2003 | 08:47 PM
Car: 85 Camaro SC
Engine: V6
Go to your gas tank and follow the lines that come out of it, you should come across a 6inch long 2.5 dia cylinder somewhere under the driver side seat under the car. Unless someone removed the filter and put a hose or somehting inbetween the gas lines to delete the need for a filter
Old Feb 19, 2003 | 08:50 PM
Transmission: autos
ill have to look tomorrow but when it was on a lift i didnt see any filters other than the oil filter...erg my comp is laggin so bad....
Old Feb 19, 2003 | 08:51 PM
Engine: 5.7 / 7.4
on the 85 it's there, facing east-west. don't believe they changed the location.
Old Feb 19, 2003 | 08:54 PM
Transmission: autos
ok, yall both got 85's and said it was in 2 differantplaces...??
Old Feb 19, 2003 | 09:06 PM
Engine: 5.7 / 7.4
his is a ch*vy, they do screwy things
Old Feb 19, 2003 | 09:11 PM
Transmission: autos
the cars are the exact same...except the outtershell...so the fuel filter is in the same place
Old Feb 20, 2003 | 12:19 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
6in long? The one on my car is about 3in long, and so is teh replacement the gave me. In the hayes manul thing I think it said that the fuel filter for post 1985 models was in the rear of the car, older ones were in teh engine bay or somthing.
Old Feb 20, 2003 | 06:52 AM
Transmission: autos
i think im gonna go to the library and look in hte repair manual for the car...thanks guys
Old Feb 20, 2003 | 05:19 PM
grimesjm1's Avatar
Pyrp, I think your thinking of fuel pump locations...... they are in the gas tank for fuel injected and under the hood in carbureted
Old Feb 20, 2003 | 06:53 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Maybie i'm wrong, and I know most people hate this manual, but i'm pretty sure thats what it says. It has an appendix section for 85 and up which says the filter is in the back, where the other section claims it is up further.
Old Feb 20, 2003 | 07:27 PM
Car: 85 Camaro SC
Engine: V6
I took a pic of the filter. ITs right behind the driver seat and just infront of the rear driver seat.
Old Feb 20, 2003 | 07:29 PM
Car: 85 Camaro SC
Engine: V6
Where the light is on the gfx is where you can find the filter behind that about a foot, its up in a cubby, not exposed to any road obstacle.
Old Feb 20, 2003 | 08:26 PM
Transmission: autos
ok, il have to look at mine tomorrow ive had enough maro troubles for one night..stupid headliner...ok thanks for the info 85SC
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
