2.8 tranny and gears compatible with the 305?
Old Apr 10, 2003 | 03:39 PM
RiceKilla#1's Avatar
Ok, now I got a 2.8 V6 in my RS but there's room for a 305, now i got a 5-speed in there, will the rear gears and clutch assembly and tranny all work with the 305?
Old Apr 10, 2003 | 04:47 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Tranny, no. Different bolt pattern.
Rear gears, yes.
Clutch, don't know, but I would put a stronger one in there while everything was apart.
Old Apr 10, 2003 | 07:22 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
you need a T5 from a V8 car
rear end wise yes
V6 and V8 Drum brake cars have the same rears just different gears
Old Apr 10, 2003 | 08:51 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you can keep everything from the tranny back
to use your current tranny:
get a V8 T5 bellhousing
get the right pressure plate and flywheel (for a V8)
go to www.McLeod.com and order a 10 inch clutch disc with a 14 spline hub
spreaders of mis-information (or under-educated) is a pet peeve i have
Old Apr 11, 2003 | 09:33 AM
If I was gonna put in a 350, what would I need to make it compatible with the tranny/rear gears?
Old Apr 11, 2003 | 11:03 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
the 350 and the 305 are essentially the exact same motors, because they're both chevy small blocks. Do all the things previously stated and you can put a 350 into your car. For performance, you might want to invest in a positraction rear end.
Old Apr 12, 2003 | 01:08 AM
84Cam4Me's Avatar
I am in a similar situation. I have a 350 chevy out of a 1976 truck I am putting into my 84 Camaro. My 2.8 spun a rod... and we had the truck, weren't using it for much so decided to part it out.
I want to continue using my T5 transmission as I prefer the 5-speed to the Automatic that was in the truck.
I tried to follow the link to McLeod but it didn't work. Do you know of anywhere else to order that clutch disc with the 14 spline hub?
Also can you think of any other problems I may have with my conversion?
Old Apr 12, 2003 | 10:55 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
From what I hear, a Chevy Astro Van's clutch disc also would work, not sure if this has been verified, but that's what I've been told
Old Apr 13, 2003 | 12:10 PM
84Cam4Me's Avatar
From what I can find online, Astro Vans use either a 9.128" clutch for the 4 cyl and an 11" clutch for the v6.
I looked through years 85-91.
I might be wrong but I don't think the 11" clutch will fit. Since the normal one is supposed to be 10 - 10.4". Unless I would have to use the entire clutch assembly with exception of the flywheel.
Old Apr 13, 2003 | 09:56 PM
nope it will not
they used an 11 inch clutch disc
stock on a 305 with a T5 in a thirdgen is 10.4
plus you would need a 168 tooth flywheel which will not fit inside a 3rd gen's T5 bellhousing
swap to the Astro bellhousing you say?
sure, if you dont mind your shifter sitting 12 inches further to the right than it is now............................................... (in other words you cant do that either)
Old Apr 13, 2003 | 09:58 PM
btw, i guess i should add that i searched for a compatible clutch for about 6 monthes
just buy one from McLeod and save yourselves tons of trouble
(McLeod is the only place i found that has a compatible clutch)
Old Apr 13, 2003 | 10:10 PM
84Cam4Me's Avatar
I found the website. www.mcleodind.com
Old Apr 14, 2003 | 02:21 AM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
nope it will not
Hey thanks for the answer, it's good to know... I'll stop spreading the misinformation lol
jklein337
Sep 19, 2018 06:23 PM
E Rod
Aug 28, 2015 05:17 AM
drathaar907
Aug 6, 2015 04:20 PM
