damm car keeps skiping
Old Apr 15, 2003 | 08:33 PM
Xceleratemaro's Avatar
my car keeps skipping when its running...i have a new fuel filter wires plugs cap roter coil fuel pump modigule
i have an exhaust leak
what could it be??
Old Apr 16, 2003 | 02:07 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
What do you mean by "skipping"? Many possible meanings.. Chugging, lurching, bucking, misfiring, etc.
Does it do it during acceleration? Any check engine lights? Does hard acceleration make the problem go away? Any cruise throttle/deceleration problems?
Gotta get specific bro!
Old Apr 16, 2003 | 04:05 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
I think he means missing. Put in a new pick up coil in the distriuator. Does your tach needle twich when going a constant speed.
Old Apr 16, 2003 | 06:04 PM
here it gose ...no check engin light becouse i took the bulb out...now the car dose not skip at hard exceleration but dose have some trouble at slow exceration. now i have an exhast leak could that be fouling my plug up...or could it be something else. what's a pick up coil and what dose it do..? how much are they? are they hard to chang out?
thanks for your help chris
Old Apr 16, 2003 | 06:25 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
first of all, put your light back in. It tells you if something is wrong with the car.
Old Apr 16, 2003 | 06:34 PM
my car just roled over to 190 thousand miles the damm thing is still running im happy my o2 sensor is not hooked up becouse the wire broke but sence the car ran fine a month ago i could give a **** about the "check engin light" i do not need that to tell me something is wrong.. you can hear how the motor is running..
Old Apr 16, 2003 | 08:23 PM
Nixon1's Avatar
Plug the light back in and check your codes..see if you get anything besides O2 sensor codes. Otherwise, you'll be running around in circles changing parts out trying to solve the problem when the solution MIGHT be right under your nose.
Pick up coil is down in the distributor somewhere..not sure where....I think mine on the Camaro was trashed, but the car never acted up...I just had no operating tach. Needle never went below, maybe, 5000 rpms...tapped the gas and it spiked past 7000. Friends of mine always laughed and yelled "She's gonna blow!"
Where is your exhaust leak at?
Old Apr 16, 2003 | 08:37 PM
i might just put it on my dads snap on scanner the exhast leak is on the left bank back right at the head
Old Apr 16, 2003 | 09:07 PM
Nixon1's Avatar
Your exhaust leak is at the head??? Holy christ.. That's gotta be wreaking havoc with that cylinder...
Old Apr 16, 2003 | 09:09 PM
more than likely....im to lazy to put a gasket in place becouse hopefully i will put my v8 in about 2 mounths...
Old Apr 17, 2003 | 01:14 PM
Nixon1's Avatar
Ok I had a brainfart earlier...it's not THAT bad, but it's not good! That thing must tick like crazy....
Old Apr 17, 2003 | 02:41 PM
yea it is
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
