Can someone tell me just what the heck this is?
Old Apr 16, 2003 | 10:44 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
The large plastic 'thing' in the center of the pic -
Attached Thumbnails Can someone tell me just what the heck this is?-mvc-003f.jpg
Old Apr 16, 2003 | 10:45 AM
Doward's Avatar
Oh yeah, it didn't always sit there, I ziptied it. Seriously, it was screwed on next to the ignition coil, with 2 vacuum lines coming off it.
Old Apr 16, 2003 | 11:41 AM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
thats your egr vacuum solenoid...
Old Apr 16, 2003 | 01:04 PM
Doward's Avatar
Oh... damnit... some remnant of EGR remains on my car!!! grrr... Do I just cut it off? I couldn't find a plug for it...
Old Apr 16, 2003 | 07:45 PM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
i would say its not needed if you're not running an egr valve...and to just take it out...as long as nothing is connected...there is also an electrical connector that goes to it because it is operated by a sensor...so you might throw a code...i'm not sure...hope i helped...
Old Apr 16, 2003 | 10:26 PM
KED85's Avatar
I'll pay for shipping it to Los Angeles!
Old Apr 16, 2003 | 11:10 PM
Doward's Avatar
Seriously? You want it, email me... I think I'm gonna have to cut that thing's wires tho... the damn thing must plug into the bottom of the map looking sensor next to the ignition coil...
Old Apr 17, 2003 | 11:59 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The Map-looking sensor is the vacuum diagnostic switch for the EGR. If the computer activates the solenoid, but the vac diag switch doesn't "see" vacuum (from the solenoid), the diag switch tells the computer that the EGR didn't work, and you get an EGR code. That's why the two are wired together. The diag switch will be somewhat fragile if you want to separate it from the ignition coil bracket...
Old Apr 17, 2003 | 12:13 PM
Doward's Avatar
Every friggin' thing in this car is fragile. It's all PLASTIC for Chrissakes!!
/rant
I'll see what i can do on it... found my vacuum leak - where I blocked off the EGR tube into the intake plenum
Loudnproud86
Jul 14, 2016 12:59 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
DonW
Carburetors
Sep 23, 2015 08:04 PM
aharvel50
Sep 21, 2015 07:31 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
