turbos on V6
Old Apr 28, 2003 | 10:19 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Transmission: 700 R4
turbos on V6
ok here's the deal. Do tubochargers attach to the exhaust or to the air induction unit? After seeing several pictures it looks like there are types for both.
Old Apr 28, 2003 | 10:27 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Every turbo connects to both.
Old Apr 28, 2003 | 10:29 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
which is the better way to go?
Old Apr 28, 2003 | 10:32 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Ok, first things first, go get Maximum Boost by Corky Bell. I think it'll answer 99% of your turbo related questions in there
Old Apr 28, 2003 | 12:21 PM
Soft Taco's Avatar
they connect to both.
Turbo's use the exaust to spin the turbine. (Instead of a belt like a supercharger.)
Old Apr 28, 2003 | 03:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's why, in theory, turbos can "spin up to infinity"- a supercharger's speed is limited to that of the engine.
Old Apr 28, 2003 | 10:58 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Yep... also, a turbo isn't boosting all the time... just above a certain RPM which is above cruise speed in most cases... which means better gas mileage than a supercharger...
Old Apr 29, 2003 | 06:01 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Plus, with a boost controller, you can change your maximum boost pressure on the fly if you're not using it, i.e. limiting it to 3 psi while commuting, thus further increasing gas milage.. press a button, and you've got 10 psi max.. or 25.. depending on how insane you are... *evil grin*
Old Apr 29, 2003 | 08:07 PM
funstick's Avatar
there also the trick required to make the computer see boost. hmm makes you wonder. add fuel and correct timming as well as reduce injector pw so you can run bigger injectors
Old Apr 30, 2003 | 12:30 AM
devianb's Avatar
plus those turbos are powered by your exhaust gasses. Higher rpm, more exhuast, turbos spin faster, more boost, more power.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
