Help on 86 2.8 Questions
Old May 23, 2003 | 03:22 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Does an 86 Automatic camaro have a Vss, if so, what all does it control?? What color are the wires to it??
Old May 23, 2003 | 03:53 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep; VSS should be poking out of the back of the speedometer head. Look for a yellow box. Can't help with more right now; I'll try to get my manual out and look for you over the weekend.
Old May 23, 2003 | 07:05 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I thought they came in in 87?
And Dale, you can always redo the head liner, mine is currently red. not for long.
Old May 24, 2003 | 09:09 AM
Dale's Avatar
Engine: 350 S-TPI
Thanks tom, guess dude was right. I thought they started in 90
Haynes and Chiltons dont show them on wiring diagrams
Yes, headliner will get re-re-done, since everyoen wants like 100+ or one. Geesh
Old May 24, 2003 | 09:21 AM
KED85's Avatar
I also have that yellow box on my 1985 speedo head.
I UNDSERSTAND it works with the TC lock up feature.
My TC locks at 35MPH & also at 45MPH.
I'm redoing my headliner for about $30-40!
Found supplier local.
Material at $6.99/yard.
AND it's light tan/doeskin/buckskin colored!
Actually any color can be had from this place!
AND the glue spray is $10 a can
Wholesale Upholstery Supplies of America
16140 Valerio St.
Van Nuys, CA 91406
818-786-7562
Old May 24, 2003 | 11:38 AM
Engine: 5.7 / 7.4
I'm doing my headliner in the same blue mettalic as the dash,w/silver mettalic bird on it. Hobby Lobby.
Old May 25, 2003 | 02:26 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
VSS's in the tailshaft were standard for later-year f-bodies. '86 Firebirds with idiot light dash panels got the VSS and VSS buffer integrated into a single yellow box connected to the back of the speedo. '86 Firebirds with digital gauges got the VSS in the tailshaft of the trans, and a separate VSS buffer by the ECM (also a yellow box). Not sure about '86 Camaros.
Looked it up in the GM book; the VSS takes a +12 supply from the gauges fuse on a pink/black wire. It's grounded via a black/white wire. The signal goes to the ECM via a brown wire.
Old May 26, 2003 | 10:08 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Dale: Would you mind taking a pic of your 2.8 for me? I'm still trying to make heads or tail of my engine's date of manufacture... Thanks!
Old May 27, 2003 | 02:19 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I thought the VSS came up in '89/90 along with VATS?
My '88 2.8/T5 is a straight cable speedo, with the nice little gear in the tranny tailshaft.
Old May 27, 2003 | 06:40 AM
Dale's Avatar
Engine: 350 S-TPI
bibgp, you have PM.
Doward, thats what I was thinking also. Guess were wrong
Old May 27, 2003 | 08:10 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Camaros evolved later than Firebirds, but all the cars had a VSS. Go look at the back of your speedometer, Doward... you'll see a yellow box. There were two types, like I said... those in the tailshaft (later years), and those in the back of the speedometer. Speedometer ones were optical, tailshaft ones were magnetic. You just have to lift off your dashpad to see it.. you don't have to go yanking out the whole cluster.
My '86 also has a straight cable speedo, with a regular gear in the trans tailshaft, a yellow VSS sensor/buffer behind the speedo (driven by the speedometer), and a brown wire going to the ECM.
Old May 27, 2003 | 08:45 AM
KED85's Avatar
Tom, you're saying I can easily access the behind the instrument cluster stuff, by simply removing the dash pad?
My VSS set up is identical to yours.
When/IF ya decide to lube speedo cable, USE WHITE GREASE
Axle grease wears down quick, as I am discovering, drat!
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
redmaroz
Aug 16, 2015 11:40 PM
86Base
Aug 8, 2015 01:34 PM
