i have a problem!!!help
Old Jun 5, 2003 | 09:35 PM
icebird_1981's Avatar
k well dureing tha past week i notice my temp gauge was higher.. alot higher then normal and would go so high after haveing my car on for like 1 min. anyway today i turned on my heat and no heat just cold and my temp gauge went off the chart. after i shut her off for 5 min and heat was and good temp went way down but still not normal. so tonight i was driveig home from work and gave it a try and no heat and temp is right off the chart. i am hopeing this is only the thurmal stat and not something big. what u think, any ideas?????
thanks
Old Jun 5, 2003 | 10:14 PM
KED85's Avatar
IF CORRECT
The adjust for the temp is a cable controlling the door opening in the heater box housing.
ANY reason why that could be disturbed?
Your thermostat?
I believe more a good wiring connection or poor ground.
IF really overheating, you'd have steam outta from under the hood.
Old Jun 6, 2003 | 07:29 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Yah, hopefully your temps aren't actually going that high. So no boiling over? No overheating? No leaks? The no heat thing makes me think a bad heater core..or a bad hose running to the core. Check them for leaks. There's no water coming into the passenger-side area, and no smoke rising from the dash right??
Old Jun 7, 2003 | 01:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: i have a problem!!!help
So, engine temp says "very hot!"
But, no heat from the heater?
$10 says that you're extremely low on antifreeze.
Old Jun 7, 2003 | 02:03 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Check the coolant overflow reservoir. If it's boiled over, there'll be antifreeze all over the outside of the tank. As TomP said, check your coolant. Compare the coolant level when the car is cold and when the temp gauge says your car is too hot. If the coolant level doesn't go up drastically when the gauge says it's too hot, you've got a problem with your gauge.
Old Jun 7, 2003 | 07:20 AM
to lil is not my problem 2 much is last week when i added antifreez i was talking to someone and added to much. since then sometimes when i shut off my car antifreez will drip down if i turn it off then on again it stops. my friend told me i have to much antifreez and thats why its doing that. could that be the problem for the heat and temp gauge as well?
and no, no smoke no nothing all normal and no the car is not really over heating.
Old Jun 7, 2003 | 08:38 AM
Nixon1's Avatar
Shouldn't be the problem.... Any excess coolant will just go over and drain into the reservoir tank or drip outside the radiator to the ground.
Old Jun 7, 2003 | 09:02 AM
KED85's Avatar
Last respsonse correct
EXCEPT
IF
YA
Got a weak head gasket.
My Blazer had a weak head gasket.
It would drain radiator, not show up out the tail pipe.
It would show up as a gauge going weird, then calm down again, then register high.
I'd pull over, pop rad cap, fill with water (while engine running), get going again.
Eventually, I got chocolate milk.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
