service engine soon, after thermostat
Old Jun 10, 2003 | 09:03 PM
V6RSRick's Avatar
today i replaced my thermostat, it is a 160* it
wile i was installing it, i spilled some hot radiator fluid on my airintake sensor, (it is seperate from my airintake for now) nothing got in the air cleaner tho, i think the coolant got on some other wires,
the car is back together, except a throttle body gasket. ill get one tomarrow. i fired it up and it just started to light up service engine soon. it kinda runs rough at idle, but drives great. i was wondering if anyone knows what i should check.
ohh and i think my fan is stuck on.
i checked my 2 sensors on the throttle body, i dont know what else to check, i didnt undoo anything... else i dont think.
i have never changed a thermostat before, everything is tight, no coolant leaks
please help me out, any help is apreciated
Old Jun 10, 2003 | 09:30 PM
RustBucket's Avatar
Did the light stay on??
Pull the code and see what the ECM posted. Let us know and we can go from there.
Old Jun 10, 2003 | 10:21 PM
V6RSRick's Avatar
yup, shes spittin codes at me....
12- system works
13-oxygensensor circuit
15-coolant temperature semsor circuit
23-mixture control solenoid
she may have had a few codes already b4 the thermo was installed...
i just had a new throttle position sensor installed and an iac valve
Old Jun 10, 2003 | 10:46 PM
V6RSRick's Avatar
any ideas?
Old Jun 10, 2003 | 10:50 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
What year 2.8?
I thought i read somewhere that a 160 degree required some reprogramming, as the engine never really warms up enough for the computer to be happy...
Doward's Avatar
One other thing - unplug your battery for a couple seconds, then plug it back in - clear all the codes, in case some of those were old. Then see what happens!
Old Jun 11, 2003 | 01:44 PM
V6RSRick's Avatar
ok ill unplug it, its a 1992 3.1, the car didnt run like this befor i put the new thermostat in, i hope that it will work from a fresh start...
this mornin i started her, she didnt want to go in gear, i had to slp the clutch to get it to not stall, once it warms up a little its not as bad,
Old Jun 11, 2003 | 01:47 PM
V6RSRick's Avatar
also, is the coolant sensor the pipe that goes into the intake hose that atatches to the tb? the other end connects to the passenger valve cover?....
cuz i was lookin in my haynes book, and it had an arrow pointing to something in that area, but i cant find anything that seems like a coolant sensor...
Old Jun 11, 2003 | 02:02 PM
V6RSRick's Avatar
now that i reset it, shes still spitting out code 15... the others are gone tho...
V6RSRick's Avatar
where is the coolant temperature sensor at anyways, i want details please.... whats it look like please
Old Jun 11, 2003 | 10:37 PM
V6RSRick's Avatar
i found it, the temp sensor was snaped off, i know its ghetto but i superglued it back together,
she runs good
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
