Cam and Lifter Wear Question
Old Jun 16, 2003 | 10:44 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I'm getting a used cam installed here real soon....and I forget exactly what the rules are for swapping cam and lifters. The cam is used.....and it's a different cam than the one my lifters are worn to, though I doubt that matters....lifters have 147,000 miles of wear. Can I use the original lifters with this new, used cam?? I don't wanna be going down the road and suddenly realize I've ground my lobes down to shavings. Thanks!
Old Jun 16, 2003 | 11:06 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Can you? Yes.
Would it be adviseable? Hell no.
Old Jun 16, 2003 | 11:07 PM
Nixon1's Avatar
So then what can I do? Cause wouldn't new lifters on a used cam rip it to shreds?
I already bought the cam...lifters weren't included...so returning isn't an option!
Old Jun 17, 2003 | 11:36 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
you can take the cam and break it into about 12 different paper-weights.
Old Jun 17, 2003 | 11:47 AM
Nixon1's Avatar
That's not funny! It was $100 for that cam!
Old Jun 17, 2003 | 12:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If a roller cam then yes, can re-use lifters that are in decent condition. If flat tappet then the lifter that was broken in with each lobe must stay with that lobe.
I've known folks to put new flat tappet lifters on a used cam. Sometimes it works, sometimes is doesn't.
RBob.
Old Jun 17, 2003 | 01:10 PM
Nixon1's Avatar
Everything I've read so far tells me it's a roller.
Old Jun 17, 2003 | 03:32 PM
Doward's Avatar
Oh wait, that's right, you've got the 5.0 'stang.... shoot, sorry man!
If that's the case, yeah, you got a roller, and yeah, you can use your stock roller lifters on it.
Sorry bout the mixup man!
Old Jun 17, 2003 | 10:29 PM
Nixon1's Avatar
Whew. Thank ***. I was freaking just a little bit there!
Good news...the gaskets came in...so my car gets done this weekend! Ahh...I can almost taste the extra power....
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
