TomP
Old Jun 27, 2003 | 12:37 AM
Really-Slow-RS's Avatar
TomP
I won't lie my car should run better, and a good tune-up would probably do it. Everybody talks about it and everybdy wants one, but what exactly is a TomP tune-up. Whatever it is, I need to know because my car needs one, at least so I don't get embarassed by that 4-door Corolla with a header, exhaust, and a 5 speed at the track again. Please, somebody feel my simpathy and tell me what a TomP tune-up is.
Old Jun 27, 2003 | 12:43 AM
F585's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=162251
Old Jun 27, 2003 | 12:52 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
TomP's Major TuneUp is the first step when you get your new vehicle. It is the first thing you do to it. I believe it is also trademarked, and patent pended.
Old Jun 27, 2003 | 12:25 PM
The only thing I haven't done on that list is reset my TV cable and change my PCV valve. All the rest of that stuff is new right down to the K&N filters. I'll do these two things though and see if they make any difference, thanks guys.
Old Jun 27, 2003 | 12:33 PM
Doward's Avatar
Well hey, a couple notes here -
Just what feels... off... about the car? Is it smooth, steady, or does she have fits?
And what'd you run at the track?
Old Jun 27, 2003 | 12:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Another thought, too.... have you verified that your balancer ring hasn't slipped? The balancer's made of 3 parts: inner hub, rubber isolation ring, outer ring. The rubber isolation ring deteriorates over time. This can cause the outer ring, which contains your timing mark, to move. Bring #1 (front Driver's side, not front passenger side) up to TDC of the compression stroke and make sure the balancer mark lines up with 0 degrees on the timing tab.
Old Jun 27, 2003 | 03:18 PM
She throws fit every now and then, she coughs and sputters from the get-go, other times she runs perfectly. The harmonic balancer is brand new and timing is set to stock specs. Could a vacuum leak do this? I have thought about this, but she only does it sometimes that's what confuses me about the situation.
Old Jun 28, 2003 | 03:37 PM
Oh, I ran an 11.72 in the 1/8.
fasteddi
Sep 10, 2015 09:32 AM
squirrelybird
Feb 19, 2003 08:25 PM
loomdog32
May 1, 2002 10:21 AM
CaliCamaroRS
Mar 12, 2002 12:08 AM
