Compatibility 2.8 to 3.4
Old Aug 9, 2003 | 10:30 PM
  #151
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Originally posted by LT1guy
Hopefully the larger bore size will compensate for the compression loss.
3.4 compression: 9.0:1
2.8 compression: 8.9:1
Maybe all us 3.4 swappers should get membership business cards made
Old Aug 9, 2003 | 10:49 PM
  #152
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
On nearly any used harmionic dampner, there will be a noticeable ridge left in the machined surface by the rubber crank seal in the timing cover...which causes a leak. Rather than throw away an other wise good part, you smear a little locktite on the hub, and tap the sleeve in place, giving you a nice smooth surface again. It works pretty well.
Hmm, I haven't personally seen or used any that were bad enough to need that sleeve with a new seal, that's why I ask. If they were I'd buy a new one, or a better condition used one. But I guess that's me.
Old Aug 10, 2003 | 01:27 AM
  #153
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
I have a question not regarding the 2.8-3.4 swap... My car was not equipped with a tach. If I go out and get a gauge cluster w/ a tach on it, How and where do I hook it up? I was thinking somewhere on the distributor... let me know if you have any Idea... And keep you fingers crossed I am gonna try to fix my leak tomorrow.. Well, technically today. I know its coming outta the Intake....
Old Aug 10, 2003 | 11:02 AM
  #154
KED85's Avatar
When searching for used gauge packages....
the oil pressure MUST read 80 lbs (that indicates it's a V6 set up if no engine) & the tach has the "6" cylinder chip within for proper RPM reading.
MAKE SURE you get the right year speedo set up for your car.
My 1985 is cable driven off tranny.
I also took the plug for the gauge package set up from the wrecked car. I will make the current car wiring harness a duplicate of the gauge plug harness. I "think" that may be easiest path. IF I just plug in my gauge set up to the current idiot light back plug, I blow a fuse.
The heads is new info to me, THANKS
I only have what the GM book says and I set valves & leave them.
Keep dishing out the info.
Old Aug 11, 2003 | 01:47 AM
  #155
OK. I got all of the gaskets replaced. How long should I wait to start the car and it be ready for driving. The instructions on the packaging for the RTV Red high heat stuff said 24 hrs... I got it set around 8pm and I need a car by 2pm tomorrow thats about 18hrs should I let it sit or do you think it safe?
Old Aug 11, 2003 | 09:57 AM
  #156
KED85's Avatar
I suggest,
IF the car is operating normal & idling well, give it a shot!
IF the car is accelerating poorly, wait until ya got that problem solved
And the engine itself is running at 180*. also when not exelerating just crusing. its like Chuging. like a train but smaller scale
The 3rd Gen F body with a 3.4
PULLS LIKE A FREIGHT TRAIN,
not runs like a freight train!
Keep at it, you'll solve the problems!
IF all was good (sensors/connections) before the swap, your time & money will NOT be wasted effort!
My 3.4 swap failures include
Cat Convertor
Transmission (to much 3.4 power for the "rebuilt" tranny!)
MAS Sensors
Fuel pump/filter
Oil filter housing gasket
Alternator/ICMs (alternator voltage spike fried ICM-6 of them!)
AC system (I love R12!)
Failed trannys after the 3.4 swap are number one complaint! Unless tranny was rebuilt prior to engine swap.
Keep at it!
Old Aug 17, 2003 | 11:52 PM
  #157
Hello, I replaced the gasket and it must have slipped or something since I cut it and my oil is like a milkshake I am hoping I didn't hurt the head gasket I don't see how I could have I am going to just get a new intake manifold since mine is/was on its last legs, try again and if it doesn't stop the leak and work I am just gonna rip the whole intire car apart and start over. I haven't even touched the car in a week. Do any of you know where I can get a rebuild kit for the 3.4 autozone and Advance Auto doesn't have them. I looked for one at summits website and didn't see any. let me know.
Old Aug 18, 2003 | 04:41 AM
  #158
twiztid dreams's Avatar
Car: 84 Firebird
Engine: 2.8l
now i got a stupid ? but do u have to move the motor mounts for the 3.4l on the cars chassis???? or is it direct drop in usin the 2.8l motor mount locations??????
Old Aug 18, 2003 | 05:44 AM
  #159
Engine: 5.7 / 7.4
drop in
Old Aug 18, 2003 | 10:15 AM
  #160
KED85's Avatar
Sorry to hear of your problems.
What engine gasket set?
Buy the COMPLETE engine rebuild gasket set kit for THE ORIGINAL YEAR OF YOUR VEHICLES ENGINE.
Ex.
My 1995 engine in my 1985 Firebird?
I bought a engine gasket kit for a 1985 2.8, as I was putting the 1985 stuff on the 1995 long block.
Motor mounts
When swapping to the 3.4 long block INTO your 3rd gen chassis, you use the original vehicle engine mounts.
When you buy the 3.4 from the wrecking yard, try to obtain the 4th gen 60* V6 FRAME motor mounts. Those fit the 3rd gen chassis, too.
86maro_252
Oct 10, 2015 06:52 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
usafirebird
Sep 29, 2015 11:58 PM
92projectcamaro
Sep 29, 2015 07:07 PM
spartanreaper
Sep 25, 2015 07:22 PM
