Engine tuning
Old Jul 11, 2003 | 08:32 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Engine tuning
Hey guys, I just finished installing a new engine with a 2030 cam 1.52 roller tip rockers and a cloyes chain.
The engine has approx 30k on it.
There is a ticking sound that I can hear, and my cousin can hear, but my step dad who was a front end specialist says isn't rods, rockers, or anything else too serious.
All that aside the
minor ticking is there, and it seems loudest in the fuel rail
I can't hear a cylinder miss in the exhaust or up front
the timing is dead on
I have a slight rpm drop, not very often, but its there
The pulley to balancer bolts only go in half way
The cam is probably still breaking in
Any comments/questions/concerns/suggestions/thoughts/ponderings/
Old Jul 11, 2003 | 11:57 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
your ticking could be injectors. i know a few vehicles that were notorious for loud injectors (dodge caravan 3.3L). thats a possibility.
Old Jul 12, 2003 | 02:00 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
dave's right , if you're hearing the sound from under ur intake plenum and from what appears to be the fuel rail then ur ticking noise is ur injectors. If it was from valve covers we mightthink rocker arms. Was this noise thre before u did the cam setup, or do you not remember it, or do you simply pay more attnetion to strange noises after you do anytype of mechanical work on something (they never sound right after they're done do they're finished do they?) But my guess is in injectors also, don't think it's a bad sound , although it could also be a stuck or leaky injector, but i doubt it. More likely than not, it's just the noise they make.
Old Jul 12, 2003 | 06:20 PM
Thanks, I think the third option is the one I'll take (pay more attention to every noise after workin on it) better not be a stuck or leaking injector...Rich from Cruzin performance will hear about it
Old Jul 13, 2003 | 09:22 PM
K guys, I think I may have a problem. With all the goodies that are in there, I think I should have a bit more torque than i do now. I was expecting to be able to at least get them to chirp when I got on it from a stop. Was I exptecting too much, or do I have a problem
Theres also probably 100 lbs give or take from subs amp and sub box in back, not to mention the donut and jack and stuff
Old Jul 13, 2003 | 09:28 PM
85f-bird's Avatar
Engine: 2.8L, LS1
subs, boxes, and music stuff will slow any car down. But from what i've heard (not what i've experienced ... never done a 2030 swap) that cam is made to give a lil' more upper RPM umph. But the expense of that added HP/TQ in the higher RPM's is a slower lower end. So you lose down low, but gain up high, and that's where it'll really come in hand while racing and whatnot, especially cause u'll be staying in those upper RPM's after ur 1-2 shift.
Old Jul 13, 2003 | 09:53 PM
Yeah, I noticed it a lot up high, and on the freeway, it was more ready to keep going faster, gotta get the junk outta the trunk I guess
Old Jul 14, 2003 | 01:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
For the ticking; make sure it's not an exhaust leak. You can use an old scrap of heater hose as a stethescope, just don't get it (or you or your clothing) caught in the motor!!!!!
Old Jul 24, 2003 | 04:25 PM
viperwsu's Avatar
Car: 91 Camaro RS
I've just narrowed my own ticking to injectors as well. It's kind of loud, I can hear it outside the car with the hood closed. From behind the doors on the outside, or inside the car I can't hear it anymore. Is that loud of ticking a problem, or do accell 24# injectors always make lots of noise?
I figured it was the ijnector because I could hear the ticking loudest right by the plenum, and a screwdriver to the injector, and the other to the ear let me hear a ticking that was perfectly in sync with the loud ticking.
Old Jul 25, 2003 | 08:27 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
What about the valves "knocking" against the head, when they closed?
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
