Another Problem
Old Jul 15, 2003 | 10:31 PM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
Another Problem
when my car is cold (sits all day) and i take her out in the eveing, if i take it to about 3/4th throttle or more, it seems to hesitate when it shifts, also when it is shifting into 4th, kinda like, it doesnt know if it should or not..... and it only does this cold, and the problem started 2 nights ago, after 10 mins. or so, she shifts smooth as silk, please tell me this is not a transmission problem~!!!!! thanks
Old Jul 16, 2003 | 09:20 AM
KED85's Avatar
IT MAY BE & asking on tranny side could provide better response.
YET
It could also be the speedo cable (binding & to need to be regreased).
IF tranny fluid hasn't been changed in ages, may be due or that may be wasted effort, too.
After all my tranny fun in life, I now let shop service it once a year for the few bucks.
They built it & they can back up their warranty.
I look at a 700R4 as NOT the TH400 in my 1974 Corvette, that has never been rebuilt & still shifts & can chirp tire from 1 to 2.
I think the TH400 was road tested in the TANKS GM has built. I know my Corvette acts like a tank!
Old Jul 16, 2003 | 11:01 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
my rebuilt 700r4 does the "unsure" shift into 4th sometimes.
If it warms up after a few mins, you might want to change the fluid. Beware, I have heard stories of people leaving fluid in trannys to long, and then decide to change it, and actually cause more problems, then if just leaving it in.
Old Jul 16, 2003 | 11:12 AM
Engine: 2800
i would let a garage do that work, but should i goahead and have them install a shift kit while they are underthere?
Old Jul 16, 2003 | 03:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Could also be tuneup related; if the engine's acting up, the trans doesn't know when to "automatically" shift.
Old Jul 16, 2003 | 05:25 PM
Engine: 2800
tom, i have a new coil, plugs, wires,pick up coil, module, and cap and rotor
Old Jul 19, 2003 | 08:00 PM
icebird_1981's Avatar
make sure it has all the fluid it needs, it use to happen to me, i thought my tranny was going untill i found i was leaking tranny fluid, topped it up and everything was perfect.
Old Jul 20, 2003 | 08:54 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Don't install a shift kit on a transmission that hasn't been rebuilt. It just isn't a good idea in my opinion. You want firmer shifts...try a bottle of Lucas Slip Fix. Stuff is thick as honey, good enough to not void new car warranties... And actually helped to firm the shifts up substantially in my Mustang's transmission, which is on the verge of losing gears due to 147,000 miles of age plus the engine output at the fly went from 225 to probably 325+ right now. That's never good on an old tranny.
Old Jul 20, 2003 | 11:26 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
My fiance's Volvo used to do that, we got the transmission flushed (includes cleaning out the T/C) and the problem went away. 254,000 miles and it shifts soooooo smooth. When was the last time you got a total flush. When you just drain and refill the trans you only get like half of the dirty fluid. it costs like $60-$75 to get it done.
Old Jul 20, 2003 | 07:36 PM
Nixon1's Avatar
Just remember that smooth isnt always good! Sometimes it can be a sign of low fluid pressure or slipping clutches. My buddy's 2.8 shifted awesomely smooth. And it missed gears and slipped out sometimes. My other friend ran his tranny with his TV cable disconnected. Shifted insanely smooth. And about 1 month later, while racing, he blew up 2nd and 4th gears.
Old Jul 20, 2003 | 09:45 PM
KED85's Avatar
Sounds about right!
I'm VERY IMPRESSED with the work on your Mustang & the HP figures & such..... Great going!!
Old Jul 20, 2003 | 10:06 PM
Nixon1's Avatar
Thank ya Karl! That means a lot to me! That car is basically my dream right now...I just can't leave it alone. Hell I bought an EGR valve for it today and the thing runs SO much better. It's an ongoing project.... I wouldn't be where I was with it today if it wasn't for the support of my dad, and for a really great credit card.
Old Jul 20, 2003 | 10:36 PM
KED85's Avatar
Now that I am a Dad, I know how much your statement means to your Father!
Keep enjoying all the fun ya can.
Encouragement, though only a few words, really goes very far!
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
