What is the stock thermostat for a 89 firebird?
Old Jul 17, 2003 | 02:15 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
I wan't to change my thermostat while I'm doing my timing chain so what is the stock one for a 1989 Pontiac Firebird, 2.8L, auto trans? I live in canada, should i get a lower thermostat or is this just bull**** and I won't see any performance gain? Thanks
Old Jul 17, 2003 | 02:21 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
You really won't see any type of performance gain with a thermostat that's only a couple of degrees cooler. If your car is not having any problems overheating, then I would just get a direct OEM replacement.
Old Jul 17, 2003 | 02:24 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Well that's what I wanted to do. But what is the stock thermostat for my car then?
Old Jul 17, 2003 | 02:37 PM
socialdeviant's Avatar
stock 195
good choice 180
If you live in warm regions year round, 160, but it can effect the comp...
Old Jul 17, 2003 | 02:56 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Where I live, we have snow from november to april. And from may to october the temp vary from 10 degree celsius to 30 degree celsius. So is the 180 thermostat still the best choice? And what will it do?
Old Jul 17, 2003 | 03:16 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
With yours, I'd go stock 195. As cold as it is up there, you could probably run around with no water in the radiator! :sillylol:
Seriously, you'll want the warmer thermostat.
Old Jul 17, 2003 | 03:26 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Hahaha! Thanks for the advice guys
Old Jul 18, 2003 | 11:16 AM
tj78_'s Avatar
i think my thermostat could be causeing problems for me as well, the previous owner told me he put a 160 in it, but that seems overkill to me... my engine seems to run really cold.. i have only seen it over 200 about twice on the two hottest days of the summer, it seems like it is always down around 150-160.. wouldn't i get better performance higher? 180 or so? i live in upstate ny, rochester area. i wonder if it is messing with the computer or if the guy coudlhave recalibrated it, i woudl assume no. i ahve a problem with the car down low. with real light throttle it runs rough and when you let off after light throttle it will bog right down as if to stall andthen jump back to about 1k it prob idles somewhere between 400 and 600 , i can't remmeber off hand... it s a305 tbi...
how tough is it to change the thermostat?
any help will be appretiated guys,
thanks
tj
Old Jul 28, 2003 | 12:08 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
I got a 180 for my 92 RS, and so far its working great. I think the 160 was a bit low, as the guy at the auto parts store said if I got one too cold, it could fudge up my computer. Changing a thermostat isn't too hard, I recommend investing some money into a haynes manual, as it has saved my *** quite a few times.
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
Randomtask2
Aug 13, 2015 01:57 AM
