Engine temperature
Old Jul 18, 2003 | 10:32 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Engine temperature
I'm just wondering what temp most of you guys run at...I just did the engine swap thing and now the guage actually works. So what do you guys run at?
What is considered overheating anyways?
Old Jul 18, 2003 | 10:36 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
well, mine was recently about 240* +
Old Jul 18, 2003 | 11:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
My car runs real cool...
<P><IMG SRC="http://viragotech.com/P1010206.jpg" HEIGHT=450 WIDTH=600><IMG SRC="http://viragotech.com/P1010207.jpg" HEIGHT=450 WIDTH=600>
<BR><IMG SRC="http://viragotech.com/P1010208.jpg" HEIGHT=450 WIDTH=600>
Old Jul 19, 2003 | 11:12 PM
KED85's Avatar
Mine fan kicks on at 220* & kicks off at 200*.
With AC on the fan kicks on.
MAKE SURE all air dams in place.
Old Jul 19, 2003 | 11:30 PM
Louis7184's Avatar
My Car runs at 190* fan kicks on at 190*
Old Jul 19, 2003 | 11:35 PM
all air dams?
How many are there and where are they...I know the one on the bottom that scrapes on the ground all the time...what other ones are there?
Yeah, mine's never been above 220 as far as I can tell, and usually runs at about 180ish
Old Jul 20, 2003 | 08:48 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
You've got a camaro, so you've only got one. As long as the center one is in place, you're alright. Some Firebirds/Trans Ams came with 3 piece air dams...2 sides and a center. The center is the primary piece though...that's what really gets the job done. You'd be amazed how much higher the engine temp is around the city just by removing that piece. It blew my mind.
Old Jul 20, 2003 | 05:48 PM
KED85's Avatar
This is my TEMP air cooling dam. TEMPORARY!!!
It's a rain gutter YET this is very effective.
Next pic shows the finished product for installation.
Old Jul 20, 2003 | 05:51 PM
KED85's Avatar
This is the air dam/cooling I will be installing ONCE I finish restoring/sanding/repainting the "new" nose I have.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
