How rich is it running you ask?
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Like mentioned earlier, the cat may be coated so much it is useless now
. Time to take advantage of the lifetime warranty.This is from about 5 runs at idle, & reving it a bit.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Holy crap
What did you do to that car man?!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Cool, looks like you got osme carbon out of that sucker. We had a big thread about that over at V8Buick.com between the GM upper engine cleaner and a simple glass of water.
http://www.v8buick.com/showthread.php?s=&threadid=24316
Matt
Matt
Engine: 5.7 / 7.4
I've heard a lot about it on firebirdv6.com also, but I already smoke a lot, so what's the point
Ha ha....good thing you HAVE tips, that way it sprays it away from the car. If that were to happen on mine....well...I'd have some really nasty upper control arms.
Engine: 5.7 / 7.4
Originally posted by TekViper
probably the egr and air check valves as well.
so what exactly is causing it to run so rich?
Right now I'm finishing up the interior, running it occasionally to keep bat charged.
