Uhhh help!!
Old Sep 15, 2003 | 12:21 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: 700 R4
Uhhh help!!
My car has been sitting for a while, but i have been starting it up every now and then. What i have noticed is a drip of water when the car is running! Is this the head gasket???? I am going to compression test it when i get a chance.. It also smokes a little, almost nothing as it is running. Is this a head gasket?? If this is and i have to take it all apart what are somethings i could do to freshen the motor up?? It is a 1987 2.8 Camaro. Thanks!!
Old Sep 15, 2003 | 12:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Where's the drip coming from? Slide a big piece of cardboard (or if it's in a garage, a few pieces of newspaper weighed down with rocks) under the engine compartment, and start the motor. Run it a bit, stop the motor, wait a while. Then check the paper for drips.
Is the smoke blue? Might be the valve seals; as they get old, they get small cracks in the rubber, and oil drips down the valve stem into the combustion chamber. Oil will puddle up onto the piston (until all the oil seeps back into the pan). This gives some blue smoke on startup, which quickly clears away. If the car sits for a while, there might be more blue smoke then usual on startup.
I had no smoke on startup until I totalled my car, it sat for almost 2 months without being started. After I rebuilt it, it's smoked on startup ever since. I guess the valve seals dried up and cracked from sitting for so long.
Old Sep 15, 2003 | 01:25 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
O sorry i didn't clear this up it is driping out of the exhaust!! Its more like a almost constant drip! And the smoke is white!!
Old Sep 15, 2003 | 02:29 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Check head gasket...
Old Sep 15, 2003 | 03:33 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
I did a comprestion test and it came out like this:
175 Psi O I O 165 Psi
165 Psi O I O 170 Psi
174 Psi O I O 165 Psi
Front of Motor
Uhh they are all over the place what dose this mean my head gasket needs replaceing ??? I don't mind the work i just need to know how to figure out if i need a new ones!
Old Sep 15, 2003 | 09:03 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Well, your compression is averaging 169psi/cyl. And it should be in the range of +/-10% which gives you a range of 152-186psi, so it looks like you're actually okay.
Old Sep 16, 2003 | 06:53 AM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
So what is the water from??
Something good and bad happened!! My friend just recked his iroc!! Bad
But he is willing to sell me the car because its got a brand new motor, which would be perfict for a v6 to v8 converstion!!! Good
:lala:
Old Sep 16, 2003 | 09:37 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Say you drive the car all day and then park it... after the exhaust has heated up will it still be dripping water? Did you check for coolant in the oil? A leakdown test will help diagnose a head gasket better, as would pulling the plugs and checking the electrodes... etc
LegacyThirdGen
Aftermarket Product Review
Jul 28, 2015 08:23 PM
kmcn47
Oct 28, 2011 05:10 PM
Cam-aro
Jun 23, 2006 12:24 AM
StealthElephant
Jun 15, 2005 09:08 PM
1991tealRSt-topGuy
Feb 26, 2002 05:20 AM
