clutch replacement - flywheel
Old Sep 20, 2003 | 10:10 PM
mrzud's Avatar
Should I resurface the flywheel when changing the clutch? Why?
Old Sep 20, 2003 | 10:20 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Yes, I always do, in fact I'm putting my new clutch in tommorrow with a resurfaced flywheel.
When you replace the clutch with a new disc, it will need to seat itself, instead of trying to seat into what has already been worn by the previous clutch disc. Same as when replacing brakes.
Old Sep 20, 2003 | 11:10 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Absolutely. You'll get better wear-in and a better feel.
Old Sep 20, 2003 | 11:27 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I will be honest and say I didn't have mine done. BUt it looked good, felt smooth and was just more money I didn't have.
$125 new tranny
$120+ clutch kit
$35-40ish clutch slave cylinder n new fluid
$10-15 hi temp neon green paint
I had to cut a corner some where. If ya got the time and the cash, Id get it done just for the hell of it. If it looks good and is smooth with no stress cracks you could let it go like I did.
Matt
Old Sep 21, 2003 | 12:22 AM
Like Gumby said, if you don't have the money you can skip it. I mean you can put new brake pads on and not machine the rotors, and you can put a new clutch in and no machine the flywheel, but if you have the money, definitely do it.
Old Sep 21, 2003 | 02:16 PM
mrzud's Avatar
Where could I go to get that done?
Old Sep 21, 2003 | 02:23 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Anywhere sith a machine shop can do it. Find somewhere that does clutch jobs and you're set, they have got to have one, you know. If I were paying someone to put a clutch in for me, then they had etter machine the fly wheel too.
Old Sep 21, 2003 | 02:38 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
MOst any auto parts stoe can have it done. But note they just charge you a few extra bucks and send it out. Let your fingers do the walking in the yellow pagesand get a few price quotes from shops and auto parts store.
Matt
Old Sep 22, 2003 | 12:47 PM
mrzud's Avatar
Thanks for all the help.
I went to pick up my clutch kit from Advanced Auto Parts...
I opened up the box and the factory packaging was broken. I took a closer look at the everything... the alignment tool was used, the clutch had been installed.
I am so pissed off. They tried to sell me a used clutch kit. When I told them it was used, they told me it wasnt!!! I pointed out the markings from the screws where it had been mounted and the markings on the alignment tool and they still tried to say it was not a used part. Even the booklet that came with it had greesy fingerprint marks on it.
I just cant believe them!
I will never buy from there again!!!
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Bryan F
Aug 18, 2015 02:28 PM
rsrmoore
Aug 7, 2015 08:44 PM
