MAF test/upgrade
Old Sep 23, 2003 | 08:09 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
MAF test/upgrade
Can you take your MAF somewhere and have it tested? I'm not talking about tapping the MAF during idle.
Also, is there an upgrade, or has anyone ever tried a MAF upgrade to a larger size?
Jason
Old Sep 23, 2003 | 08:26 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
V8 MAF's won't fit- I know, I own 2 of them along with an entire TPI intake and harness.
Old Sep 24, 2003 | 12:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Go to http://www.sunpro.com , click on the garage sale link, click on test and tune, and buy their sensor testor for cheap; it tests MAF sensors.
Either that or any shop with a computer can show what the MAF is reading.
What's wrong with your MAF?
Old Sep 24, 2003 | 07:00 PM
Nothing's wrong with the MAF. I was just curious for future reference. Thanks Tom.
Old Sep 24, 2003 | 10:06 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
no you guys can't upgrade them
Old Sep 24, 2003 | 10:14 PM
Like hell I can't. You wanna say that to my face? Just kidding.
The reason I asked is because I found this website selling MAFs for trucks (I think GM trucks) that were upgrades from stock (larger of course).
I was thinking if you're loaded, you can pull apart the one for our car and mount it in a larger tube.
Old Sep 24, 2003 | 10:15 PM
fly89gta's Avatar
Car: 2018 Camaro SS
you'd have to be VERY VERY carful to swap the guts of a MAF into another tube, can it be done? yes...is it worth it? eh...debatable
Old Sep 24, 2003 | 10:30 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
is it worth it? how about 'no'?
the maf/ecu are calibrated to that size tube. Increase the tube, the ecu will interpret the maf's signal wrong.
You'd need major reprogramming.
Old Sep 24, 2003 | 11:01 PM
I'm not disagreeing with you Doward, but I can't see why it would matter what the size of the tube is, unless the board inside needs to be in a certain proportion to the size of the tube.
Old Sep 25, 2003 | 04:47 AM
Doward's Avatar
Actually, it's the flow of air through the tube that's important.
it's 5:30 am, so I'm not really up to the math part of it, but in a nutshell -
Smaller pipe = higher velocity for the same flow
Bigger pipe = lower velocity for the same amount of flow
WIth a bigger pipe, the MAF reads it as a slower velocity (the air flow) and hence, the ecu reads it as less air.
The key would be to go from a 3" to whatever size flows exactly half the velocity for a given air mass (or double the air mass at a given velocity) and then recalibrate the ecu accordingly. But as far as I know, the MAF scalar tables are still a huge item of mystery....
Old Sep 25, 2003 | 05:42 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Doward is 100% right. I forgot all about that.
Old Sep 25, 2003 | 10:59 AM
Well, I guess it would have helped if I knew how the MAF worked. Now that you tell me it works on velocity it makes sense. I should have known it had something to do with Bernoulli's Principle.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
