missing at 3/4 to wot
I have a 2.8 85 camaro at 3/4 throttle the car will start to miss. I have changed the distr cap and button, new wires, new coil, new control module, and the plug are less than a month old and they are bosch platinums, and I check my fuel pressure and it was 38psi. the problem started when I was at a red and it turned green and the civic next to me took off so I down shift to 1st and floored it and the rpms went up to the shift point and then it started to miss. I have a (at) transmission and it was just rebuilt about 3 months ago. if you have any suggestions please reply I am about to shoot my car.
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
What's the shift point?
Also, does it miss in neutral, if you hold it at like 4500 rpm+?
Mine did that.. turned out the be the coil... but yours is new.
I'd check the injectors.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Try the plugs anyways. they could easily foul and still look nice, if other parts were failing. I have solved several money pit problems with some plugs n wires. 2nd n 3rd gens eat good ign parts like candy.
Matt
Matt
its does not have that problem in park or neutral, but I guess I will try the spark plugs which one should I goes with I have had the regular ac delco and they worked fine, should I go with those?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ANy plug is good new. I like accel u groves myself, but a bit pricy. Good ol AC Delco work too.
Matt
well I change the plugs today and they weren't bad but I change them anyways to see if they were the problem. I put new autolites in and they didn't fix the problem! So if anyone else has any suggestion please post them!
thanks guys for all the help but it actually turn out to be a bad maf sensor. but I got a new fuel pump and filter, new spark plug wires and new bosch platinum for next time. but thanks for all the help car runs great now. now off to the next problem.
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Mine is essentially doing the same thing right now. I went on a rather long cruise yesterday and started to notice it near the end. Looks like I have that to look forward to.
Pac J
May 17, 2020 10:44 AM
Damon
Sep 26, 2015 04:29 PM
