MAF question
Old Oct 23, 2003 | 12:19 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 700 R4
MAF question
I have a MAF from a 90-92 2.8L off of a junked camaro. I have an 89 2.8L so i tested the MAF on my car, but doesnt work . It makes the engine stutter and it doesnt run correctly until it starts moving. Im not sure if the part is bad or if its a different part number than the one on my 89. Are there any differences in the 89 MAF and the 90-92 MAF?
Old Oct 23, 2003 | 12:43 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
It can't be from a 90-92 Camaro if it has a MAF. The 90-92's were Speed Density (MAP) and don't have a MAF. Plus 90-92's were 3.1L, not 2.8L. If it looks the same and has the same 3 wire(?) harness w/ the orange film inside, it should be the same. As long as you don't have the V8 version, which is a heated wire inside.
Old Oct 23, 2003 | 02:32 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
here's the one i have. (not the one on the car now)
Old Oct 23, 2003 | 02:34 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
another...
Old Oct 23, 2003 | 04:32 PM
89V6FBIRD's Avatar
That's a 2.8 MAF. It'll work on your 2.8 Camaro. (Firebird MAFs are a little different because they have a 45 degree bend on the end)
Old Oct 23, 2003 | 05:54 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
that one looks a little different than the one in the car now though. On this one, the chip is green and tick but the one in the car now isn't.
Old Oct 24, 2003 | 10:10 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
well it might not work right b/c the MAF could already be shot, thats the problem with taking them out of junkyards, how many miles were on the car u took it from?
Old Oct 26, 2003 | 04:33 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
I cant remember exactly how many miles were on teh car but it wasn't an extreme amount. I actually found it in the back of a fire hall. The fire hall was practicing on it and cutting it up but i got to it before they touched the front end. They said the car ran before they chopped it up. Kind of a waste of camaro if u ask me.
Old Oct 26, 2003 | 05:27 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
your kidding me???!! a fire dept used a camaro for a demo,i better never see any of our members using one of them for that purpose!
Old Oct 28, 2003 | 01:59 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I know this is quie obvious, but, did you check the relay? Mine did the same thing until I switched it with a new relay....
Old Oct 28, 2003 | 03:24 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
here's a pic of the MAF thats in the car now. are they both interchangable?
Old Oct 31, 2003 | 11:14 AM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
is there any difference between that one and the green one?
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
