2.8 that just won't go
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
hey, i havnt posted in the last couple of months, but ive been so busy with school (and i bought a truck, no longer having a transpotation problem, i let the Fbody sit till i had some time) well, she's ready to go, but it just wont turn over, it will crank and crank and nothing, ive got a new fuel pump, new starter, and im not getting any codes, just wondering if i could get a few idea's cuz this thanksgiving break im gonna get her back into decent running condition, hopeing for some serious work this coming summer! thanks,
Engine: 2800
a fantastic white spark, couldnt tell you the pressure, i don't have the equipment for that, but i can tell you that it does have some kind of a voltage drain, (i will charge the battery to full, it's a new battery, and in the morning w/o touching the car, and it's dead as a doornail)
Engine: 2800
okok, alt is new too.... uh, somebody said somthing about the Regulater, im pretty sure i know what that is but you think you could jog my memory? would that cause the low pressure?
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
the injector regulator controls how much fuel pressure you have. Its the black thing on the fuel rail.
If you have a voltage drain, thats it.
Could be Alt (even if its new)
starter
radio
lights
any wires crossed in the system. Start pulling fuses at night to see where the drain it is.
starter
radio
lights
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Regulator is vacuum fed, has no electrical connections. That's not your drain problem.
Engine: 2800
ah, but it might be why the car wont start if it's no good, i think that even with the drain, it would still start when the battery is fully charged
Car: '92 Firebird
Engine: 3.1 Liter v6
Transmission: 700r4 w/shift kit
try getting some ether/starting fluid....comes in a spray can....read the directions carefully.....and use it as directed.....this stuff can be dangerous.....:nono:
even without enough fuel pressure.....this might get the engine started......but it might die shortly after........
but you should definately check wires like dale said......but.....also like you said.....with a brand new battery it should turnover.......
unless you are just charging a battery with a bad cell.....
have your battery checked out.......
then get a new one.....or a good one......and try again to start it....with the good battery....good luck......
have your battery checked out.......then get a new one.....or a good one......and try again to start it....with the good battery....good luck......
Engine: 2800
ill give all that stuff a go the next time i'm home, is there a specific way to check the fuel pressure regulater? is that somthing worth pursuing?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
starting fluid is a good place to start, it will atleast tell you if the engine is getting enough spark. It should try and start/ spit and pop. If that is all it does with starting fluid, it has to be fuel related.
If no suts or pops with starting fluid, its spark related.
I have never found a car battery that liked to sit. Even for a little while, it can drain a battery down to a point where it wont recharge or start the car.
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Did you check you cap and rotor.. Last week. My car wouldn't start and I was still getting spark. The cap and rotor were only about a month old... I checked it and they were shot... As for the battery I'm not sure.. Could be you voltage regulator. Or just a bad battery...
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Car: 1989 Iroc-Z
Engine: 5.7L TPI
to run the fuel pump using the ALDL, you will need to put 12 volts to pin "G" (bottom left corner of ALDL) and ground.
The Trickster!!!!!!!!!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Matt
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
[F][E][D][C][B][A]
[G][H][J][K][L][M]
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Originally posted by Gumby
[B]Any ground or the A slot ground in the ALDL???
[F][E][D][C][A]
[G][H][J][K][L][M]
[F][E][D][C][A]
[G][H][J][K][L][M]
Car: 1988 Camaro RS
Axle/Gears: 3.42's
it could...if it got stuck in the wide open poosition. I would say that 99.99999% of the time the regulator goes bad because the lttle rubber diaphram inside doesn't hold a vacuum anymore, meaning that it would immediatly go to the "closed" position, which is where it's at at idle. To see if you are truly flooding, pull the plugs, if they are wet, then you know that you are running WAY rich.
the_hamturdler
Sep 30, 2015 12:50 PM
