4 those who don't know SeaFoam
Old Nov 21, 2003 | 07:07 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I did a little show & tell project today.
(link to cardomain site. you have been warned)
Enjoy:
http://www.cardomain.com/memberpage/325040/9
Old Nov 21, 2003 | 10:34 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
How'd the car run after you were done with that? Any significant difference?
Old Nov 21, 2003 | 10:51 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Cleans the carbon out right?? I could do this, once I find a place that sells sea foam.
Many years of carbon build up.
Old Nov 21, 2003 | 11:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Only place to find it is at NAPA or on line.
Its one of them odd products NAPA sells that work. Them secret Old Guy products. There is also another one there with a white odd green label and its called chain lube. Its a miracle bolt loosener.
But one of them Old Guy tricks, Marvelous Mystery Oil is one of them too. They use it in everything often.
Sea Foam is big in the Virago bike world. It keeps the carbs fresh and clean.
http://www.seafoamsales.com/
Matt
Old Nov 21, 2003 | 11:43 PM
Engine: 5.7 / 7.4
I actually got my SeaFoam @ Advance Auto while visiting a friend around the Pittsburgh area (Sewickley). $4.99
Marvelous Mystery Oil I've seen at every AZ so far.
The car actually idled below 1000rpm, about 800 when the stuff finished burning off.
Old Nov 22, 2003 | 12:28 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive seen sea foam in many parts stores havent used it yet. Berreymen also makes a good upper engine cleaning kit, Ive got them from checker.
Ive used marvel before dident notice any difference except when I mixed it with the gas in my gokart. Seemed to help it with overheating problems.
Old Nov 22, 2003 | 01:31 PM
Orinackra's Avatar
I'm not near Sewickley, but I'm gonna check some other local ones. Maybe others in the Pittsburgh area have it.
Old Nov 22, 2003 | 02:02 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
that stuff works wonders! :hail:
Old Jul 19, 2006 | 04:44 PM
Eltro's Avatar
I just got a new catalytic converter installed today because the other was clogged. My engine still idles rough and I've already changed the plugs, wires, and fixed the cat and i'm thinking of doing this using seafoam. What's the chance my new cat will get clogged again by doing this? Thanks
Old Jul 19, 2006 | 08:43 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I'm not making any promises but it says sensor and cat safe right on the label.
Old Jul 19, 2006 | 09:32 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
O'Reilly's sells this stuff too
Old Jul 20, 2006 | 02:49 PM
stoned_pimp420's Avatar
Car: 1990 Buick Century (pimped out
Engine: 3300
Transmission: 4 spd auto
Axle/Gears: ??????????
I swear by that shiznit man, seafoam finds it way into everything I own all the way down to my riding mower
Old Jul 20, 2006 | 05:20 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Bought a can today, don't do it at an apartment complex either. LOTS of smoke. Had to go for a drive, didn't want to **** off any other people living here.
How often do you guys do this??
Old Jul 23, 2006 | 05:25 PM
Engine: 5.7 / 7.4
WOW!!!, old thread, but maybe this shows again the power of
I really don't know the frequency of doing it, but it shouldn't be needed to be done to often. Gonna do my GP soon, and now that the bird is running again* I'll hit that too.
* open manifolds like the 3.4 was way back when. Sounds lower ptiched than the 3.4, more boat motorish, but then it is a sbc. Hopefully I'll have better luck w/the y-pipe this time.
LT1Formula
20
Nov 14, 2015 12:02 AM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theshackle
Aug 23, 2015 03:49 PM
