Anyones check engine light ever burn out?
Old Nov 24, 2003 | 09:30 AM
LT1guy's Avatar
Car: 1987 Trans Am
Is it a bulb, or part of the printed circuit?
Old Nov 24, 2003 | 10:03 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Bulb blew on mine. Swapped it with the airbag light.
Mines newer dash then yours though.
Old Nov 24, 2003 | 10:51 AM
BitchinRS's Avatar
They all should have bulbs that can be removed. Depending on the year it might be a littel different then the newer ones, but still the same concept.
Old Nov 24, 2003 | 11:43 AM
LT1guy's Avatar
Car: 1987 Trans Am
Its an 87, Redraif's car. Cool, changing a buld is no big deal, but finding another printed circuit can be a real PITA. Thanks!
Old Nov 25, 2003 | 05:16 PM
Ovrclck350's Avatar
hope ya get it fixed
Old Nov 28, 2003 | 10:34 PM
LT1guy's Avatar
Car: 1987 Trans Am
Ok, this is weird...the light actually works now when the car is running (there is apparently some kind of code set), but when I jumper the A and B terminals(ignition on, engine off, done it hundreds of times) to check for a code like normal, the light doesn't even come on...no code 12, nothing. Its apparrently not the ECM, either, since we swapped in a known good one (new) and it still does it. The ECM is switching into the right mode, since the fan does come on like normal when jumping the terminals, it just wont illuminate the light at all.
Old Nov 29, 2003 | 12:33 AM
Ovrclck350's Avatar
| 1 2 3 4 5 6 |
| 7 8 9 10 11 12 |
you're doing 6 and 12, right?
Old Nov 29, 2003 | 07:09 PM
LT1guy's Avatar
Car: 1987 Trans Am
Yeah, I even checked the manual to be sure I was jumping the right terminals. Could it be a bad PROM, since that was reused from the old ECM? I can't imagine the new ECM is bad, and in the same way I thought the old one was.
Old Nov 29, 2003 | 07:13 PM
Dale's Avatar
Engine: 350 S-TPI
I kind of had this same problem on my engine swap in the s10. I thought it was my wiring.
Light would come on when theirs a code, but I tryed jumping it and nothing.
I never found the problem
Old Nov 29, 2003 | 09:18 PM
Ovrclck350's Avatar
it's gotta be wiring to the ALDL
Old Nov 29, 2003 | 09:40 PM
LT1guy's Avatar
Car: 1987 Trans Am
I guess we'll try another PROM first, and see what happens...I really hope its not wiring!
Old Nov 29, 2003 | 10:14 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
wouldn't it be 5 & 6 jumpered? Only codes I got/still have are TPS & MAF related. other than when they first blink every so often, the SES light stays off.
Old Dec 1, 2003 | 02:31 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I jumped 5 & 6 when i pulled my codes. It must of worked, it flashed 12 and then the oh so fun code 43.
Old Dec 1, 2003 | 02:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've always jumped 5 & 6 together, too.
Old Dec 1, 2003 | 05:28 PM
LT1guy's Avatar
Car: 1987 Trans Am
Actually I was using 5 and 6...I was pretty tired when I replied. I just verifed with the manual, so I know thats right. We're going to try another PROM tomorrow night, and hopefully that will fix it.
Old Dec 1, 2003 | 05:59 PM
Ovrclck350's Avatar
Ah, well the tech article on here says 6&12
Old Dec 5, 2003 | 11:19 AM
IROC57TPI's Avatar
I remember when I was a young lad I had a old Caprice for sale that had the check engine light on. I didn't know squat about diagnosis back then so I pulled the bulb out, hooked a few wires up to it and ran them into the 110AC outlet to blow the bulb. Put it back in, sold the car the next week. So yeah, I guess bulbs do blow out.
Old Dec 5, 2003 | 04:50 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Ha! My wife's car has the stupid light on, we're just waiting for it to blow out, but Sense tells me to get teh stu[id problem fixed before the bulb dies...
Old Dec 7, 2003 | 12:41 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Jump 5 and 6 for sure. Those bulbs are a pita to change. The backlights for my speedo went out. Still haven't replace them all. Just enough to see. I wanna put a 240kph (145mph) cluster in.
Old Dec 10, 2003 | 12:43 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Mine never blew, but I yanked it lol
Old Dec 11, 2003 | 10:10 PM
LT1guy's Avatar
Car: 1987 Trans Am
Apparently it was a bad PROM...we put in the new PROM, and it now works fine.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 8, 2015 07:12 AM
