Removal Of Digital EGR
Old Dec 6, 2003 | 06:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Alright, this car just blew its third digital EGR in the past 1.5 years. I refuse to pay 200 bones again for another one.
How do I go about removing this damn thing. Does it require the chip to be burned?
Can I block it off, and leave it all mounted their, looking pretty with no codes, and no chip?
Old Dec 6, 2003 | 07:01 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
no codes you say? mabe try getting some exhaust gasket material on teh tube connecting to the manifold, block it off there. Also could raid teh 3.4 motors.
Oh wait, you sold it w/the truck
Old Dec 6, 2003 | 07:59 PM
Dale's Avatar
Engine: 350 S-TPI
I just want the damn thing off the car w/o codes. I'm tired of buying these POS's!!!
Yep, 3.4 went with the truck, even if I still had it, I wouldnt take it off that. It would be more hassel to remove on it.
Old Dec 6, 2003 | 08:16 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Disconnect it. If you don't throw a code then, you probably won't if you remove the entire sucker. Yeah, I'd just use some gasket material and block it off completely. All you'll probably notice that's different is the car will feel rougher going from part throttle to zero throttle. I don't think it'll greatly affect the computer. It'll just act like a broken EGR valve, minus the check engine light. Of course, I'm not sure if these GM cars throw a code for no EGR, but my Ford doesnt.
Old Dec 6, 2003 | 08:23 PM
Dale's Avatar
Engine: 350 S-TPI
They do throw a code when the EGR goes bad
Old Dec 6, 2003 | 08:33 PM
Nixon1's Avatar
Yeah, but try disconnecting it completely. The computer will probably just bypass it then and not throw a code to avoid pissing you off.
Old Dec 6, 2003 | 09:41 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
it will occasionally throw a code 32. i am running no egr on a stock chip. i have thought about trying, but have not, leaving the egr hooked up to the plug but not to the intake. i don't want all of the exhaust blowing thru my ported/polished intake.
Old Dec 7, 2003 | 12:47 AM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
you can have it calibrated out in a chip
Old Dec 7, 2003 | 08:22 AM
Dale's Avatar
Engine: 350 S-TPI
AM91, does the car studder like listed above? Also, hows the car act once a code is thrown, still driveable?
Anyone want to burn me a chip
Old Dec 7, 2003 | 12:22 PM
Car: 91 Camaro
i haven't noticed any studder that would be caused by no egr. i have noticed no difference when the light comes on, it seems to drive/run the exact same.
Old Dec 7, 2003 | 03:42 PM
Nixon1's Avatar
When I disabled my EGR, only difference I noticed is the car would jerk kinda hard when I let off the gas pedal and make a loud airy noise, like I had an exhaust leak. The EGR eliminated that jerk.
Old Dec 7, 2003 | 08:59 PM
Dale's Avatar
Engine: 350 S-TPI
am91, thanks for replying. I see your automatic also.
Nixon, yours was a 2.8 correct? And auto or manual? Digital or vacume controled egr?
Trying to see why am91 has no problems, while you did. Not saying either is lying.
Old Dec 7, 2003 | 09:09 PM
Nixon1's Avatar
Lol I might be leading you astray here dale... My car WAS a 3.1/auto, but I never messed with the EGR on it. The EGR thing was with the Mustang (5.0, auto). But it's a vacuum EGR with a computer connection.
Old Dec 7, 2003 | 09:36 PM
Dale's Avatar
Engine: 350 S-TPI
well damnit, you confusing me
So AM91 is only one who has messed with digi EGR on these?
I may have to play this week
Pilotrick50
Sep 2, 2015 12:48 PM
Night rider327
Sep 2, 2015 04:17 AM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
