Will this give me more power?
Old Jan 25, 2004 | 10:35 AM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Since I haven't sold my Firebird yet, I think I will do some more works on it. If I put a Crane PowerMax Camshaft, what will it do if it do anything? My car is all stock. I wan't some more power for cheap. Thanks
Old Jan 25, 2004 | 10:42 AM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I've got the powermax 2030, and if you can go with a more aggressive cam, do it. This one is ok, especially if you need to worry about emissions, but I hear some of the
Crower ones are better.
Old Jan 25, 2004 | 10:46 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
I don't know what you have done to your car already, but unless it's going to raise the selling price, your just wasting you money just putting a cam in it. If you want a little more kick for not a lot of money try a comp. chip, or a cat back exaust system. Too many other modifications would have to be made in order to take advantage of a performance cam installation.
Old Jan 25, 2004 | 05:35 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
Wan, you've got one of the nicest looking birds out there, and i'd say don't take anything past stock....when it comes to selling price, you'll do better w/ a well working factory setup, than a modified one....when i see "modified" i think "less moeny, he's probably screwed it up" .... on the contrary, no one will know of the cam swap unless you tell them. So, here's the deal, if you do it, don't advertise it in the sell, let the guy testdrive the car, then he'll get achance to see how strong it pulls in coparison to other v6 models, explain how the engine must be holding together better than others, and you'll be fine...but never say "i did this, or i did that" unless you run a really highly recommended shop.
Old Jan 25, 2004 | 08:18 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
My car have 114 300 miles, and is all stock, so WILL this only mod increase, decrease the power or do nothing? If it makes the car a little more powerfull I will be glad. Maybe I will keep it...
Old Jan 25, 2004 | 09:16 PM
It will definately give you more power, that was my experience anyway.
Old Jan 25, 2004 | 09:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The old timers "trick" is run the biggest cam you can and keep your hydraulic lifters. Kind of an easy choice most times.
Course emissions could suffer.
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I would like to have everyone opinions to make up my mind... If it increases anything, what is it? Torque? HP? At wich RPM will it make a change (bad or good)
Old Jan 25, 2004 | 11:47 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
it will give some.
raced a freinds 89 auto.
Me 92 5 speed 3.1.
Him, cam, heavily ported intake, injectors, exhaust, no cat, chip, and 40 over freashly rebuilt 2.8, rebuilt trans with shift kit and vette servo.
Me, injectors, slight ported intake, exhaust, clutch 120,XXX miles.
I stomped him. Even with 3 people in my car, plus sterio equip, tools ect... Yes the manual makes a big diff, but this was to 0-50. I barely hit 3rd. From go I was 2 cars, and gaining.
Unless you really want to get into it, skip the cam. Save the cash for the next car, do not waste the time. With the cam alone, you will see very slight gains anywhere in the spectrum.
SO in all honesty, if you are look ing to sell the car within the next year? just don't touch a thing. Never mind the fact that you can open problem worms when you start the job.
Old Jan 26, 2004 | 02:39 PM
The powermax cam only gives slight gains, and the rpm range is just like they advertise...1500-4500...you can feel it most up toward the top.
Overall, I'm with V6sucker. I added the cam and rockers and stuff and at the end of the day I feel like I wasted my money.
Old Jan 26, 2004 | 06:03 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
So anyone have a good mod I could do to my car for 160$ US or less? A mod that will give me a little more power... By the way I will have to do it in a shop 'cause I don't work on cars yet...
Old Jan 26, 2004 | 08:13 PM
Slowmaro95's Avatar
From: Straight outta the red light district of Highland
Car: 2001 SS
Engine: guess...
Transmission: 4 spd w/OD
Axle/Gears: 3:73 Posi
I agree. There are other options to resort to. The others have definite positives that would be more obvious. From what i've heard dropping a cam could help the gas mileage.
Old Jan 26, 2004 | 09:16 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
have you already done a tune up? how about a timing chain? if those are already done i would have the heads redone they usually have a bunch of carbon (fuel and oil) built up on the back of the intake valves. getting that fixed will give you more power and better gas mileage.
Old Jan 26, 2004 | 10:45 PM
V6sucker's Avatar
Engine: blown up
I would do the very simple things, CAI (350 intake), K&N's... port the middle intake. Does not require the removal of the base intake. If you add an exhaust, you might push 200 with that and above.
Scratch the porting and it can be done for 170-180.
you won't gain much, but at least it will sound better.
Old Jan 27, 2004 | 11:59 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
If i ever were to sell my camaro i woudl make it all stock agaiin i keep all the parts i take off. I would not buy a modded car because why do you mod a car to race it and if you race it odds are you put allot of stress on the drivetrain. One thing i cant figue out is why dont i ever see riceburners for sale? there are soo many but none for sale. I read auto trader etc have yet to see one in there only cars i see say the car has rims must see.
Old Jan 27, 2004 | 07:45 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
There
Ther are uncie benz cars ALL in my local area auto trader. Theres a Honda 2000 in there right now for 88,000!!!!! can you believe that!?! That's money towards a Porsche or Ferrari. Lots of em' just look under Honda, Mitsu, and Toyota, maybe even Nissan.
Old Jan 27, 2004 | 08:15 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Well, I think I will try to fix my code 32 and 34 then with the cash instead... The car runs fine but the SES comes on and trow these codes.
Old Jan 27, 2004 | 08:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Fix them codes [will make selling car easier] and you might wanna start asking around for a guy that does paint job in his garage.
a $99 Macao special is ok too. A cheap paint job will look nice for 2-3 years. You may even find your self wanting to keep your sleek black bird once its done.
I think everyone knows a guy who paints cars in his garage cheap if ya ask around. A factory paint job is no better than a garage one. Both will be fish eye city with no wet sanding between coats. I scoff at factory paint. You pay $20,000+ for a car and get a $50 paint job.
You said you have $160 but that would barley par for labor at a garage on an oil change
Spend $60 on codes, $100 on primer and paint. Save some cash to pay someone. I know where you can get some nice one shot paint cheap. $35 a gallon instead of the usual $35 a pint.
Old Jan 27, 2004 | 09:04 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I will fix these codes first. For the paint job, I don't think their is any place like this here in Quebec... The cheapest paint I could have I think is something like 1500$ canadian... Never did any body works in my life and I don't wanna try it, I don't have a garage, and it's -30 degree celsius outside... I would like to have my car painted black or bright red like my old GTA... A memories...
Old Jan 27, 2004 | 09:24 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
I would start on the code 34 first. Just fixing that will give you more power! If your MAF is bad Your fuel delivery rate will be off!
On your code 32, be sure to check for vacuum leaks first.
jhawkeye
May 25, 2022 06:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
