Pics of FbodTrek's 3.4
Old Feb 11, 2004 | 12:51 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
On behalf of FbodTrek, I am posting some pics of his 3.4 now running in his car.
Enjoy!
<img src="http://elite-fraggers.org/sonarun/fbodtrek/engine/02110001%20(Medium).JPG">
<img src="http://elite-fraggers.org/sonarun/fbodtrek/engine/02110004%20(Medium).JPG">
<img src="http://elite-fraggers.org/sonarun/fbodtrek/engine/02110005%20(Medium).JPG">
<img src="http://elite-fraggers.org/sonarun/fbodtrek/engine/02110006%20(Medium).JPG">
Old Feb 11, 2004 | 12:52 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yep.. spinning alt fan.. it's running.
Is valve readjustment what finally got it going?
Old Feb 11, 2004 | 12:53 PM
Sonar_un's Avatar
Car: '86 T/A
Yep, thats what eventually did it. Chilton's manual had the valve adjustment procedure ALL wrong!
Old Feb 11, 2004 | 12:55 PM
TechSmurf's Avatar
Engine: LS1, Scrap
This is not the first time this has been said, nor do I expect it to be the last. I've seen V6 and V8 guys alike nearly wipe their cams going with the chiltons proceedure. EVERYONE TAKE HEED, and ignore this section of the chiltons manual. (This message is directed to the population at large, not Sonar and FbodTrek, as they've figured it out anyway )
Old Feb 11, 2004 | 12:57 PM
Sonar_un's Avatar
Car: '86 T/A
I'm glad that FbodTrek did all the valve adjustments, I wasn't even there for it. Since both my cars are V8's, i've always adjusted them with the car running.
Old Feb 11, 2004 | 12:58 PM
TechSmurf's Avatar
Engine: LS1, Scrap
I consider the engine-off method as just enough to get it running.. even with these impossible-to-get-to V6s, valve lash is important enough to go through the pains of doing it with the engine running.. it's the only way to get it absolutely right IMHO.
Old Feb 11, 2004 | 01:00 PM
Sonar_un's Avatar
Car: '86 T/A
Yeah, its so much easier without that V6 plenum and runners in your way
Anyway, with his exhaust setup on the car (2.5" all the way back) the car sounds absolutuly beastly. Most people would have to look under the hood to determine if it was a V8 or not.
Its going to be raining pretty hard all week here, so we haven't had much of a chance to "test" it yet
Old Feb 11, 2004 | 01:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
looks good, looks clean. Good quilty pics too!!
Old Feb 11, 2004 | 01:27 PM
Sonar_un's Avatar
Car: '86 T/A
I tried to do my best, its been raining here though
Old Feb 11, 2004 | 04:39 PM
E-Z Rollin's Avatar
I plan to use the mpfi on 3.4 swap into a 92 s-truck,is there a certain year mpfi that would be better than another? Can the 92 2.8 tbi computer be used and did you have to use bigger injectors to prevent a lean condition?
Old Feb 11, 2004 | 05:21 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
If you have bolts and not studs in your valve covers you can remove them with the plenum on. You'll need some ext and swivels and need to remove the egr, alt . Its till a pita but i could not for the life of me get the valves right without the engine running and there was no way in hell i was gonna take the plenum/fuel rail off to get the vc's off then put the plenum/fr on to adjust only to take them off again to get the vc's back on...
good job. I cant wait to get my 3.4......:hail:
Old Feb 11, 2004 | 05:44 PM
Dale's Avatar
Engine: 350 S-TPI
e-z, no the TBI computer will not work.
As for which mpfi year, its up to you.
2.8 is MAF ran
3.1 is MAP ran
Old Feb 11, 2004 | 06:40 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Sweet, he posted the pictures
yeah I stopped in from work and he snapped these pictures in the driveway while it was raining. My sister took a few pictures of the motor going together I'll have Sonar post those too. I'm in the process of fixing up the bay too...
Old Feb 11, 2004 | 09:00 PM
br()bert's Avatar
Car: 85 firebird
hey i got a Q,
The 3.4 is dist less correct? And when you do the swap you use the 2.8 mani plenum fuel rail(3.4 injectors) and 2.8 dist. BUT since the 3.4 doesnt have a dist(from what i was told) what is in the hole where the dist should go?(on the 3.4) When i pulled my dist i noticed it went throught the back of the block rather than through the mani like on v8 cars.
Old Feb 11, 2004 | 09:16 PM
FbodTrek's Avatar
There's a plug in the hole
it has a shaft and bearing attached along with a gear (rides on the cam gear).
Old Feb 11, 2004 | 10:02 PM
Sonar_un's Avatar
Car: '86 T/A
Here are some pics of the process.
<img src="http://elite-fraggers.org/sonarun/fbodtrek/engine/02030004%20(Medium).JPG">
<img src="http://elite-fraggers.org/sonarun/fbodtrek/engine/02030008%20(Medium).JPG">
<img src="http://elite-fraggers.org/sonarun/fbodtrek/engine/02030009%20(Medium).JPG">
Old Feb 11, 2004 | 10:25 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
good job guys....when you gonna have some track times on it?
Old Feb 11, 2004 | 10:30 PM
FbodTrek's Avatar
Whenever the rain stops! LMAO. I can barely drive the car in the rain now. going down the highway feeder at 45, if I mash the accelerator slightly, the thing gets frisky when the tire (just one ) breaks loose and the car wants to go sideways... I didn't think the power change would be so dramatic! Spinning in third at 45 MPH!!! Rain or no rain, it was a rush-for a 6 pack anyway
Old Feb 12, 2004 | 06:20 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Not to rain on the parade (really, awesome work! How'd you do the plenum like that?) but either a) your 3.4 is down on power, or b) the 3.1 + MTC-5 cam is putting down the same power you are because if I nail it in the rain in 3rd or 4th, it spins! I'm talking driving along at 60 mph and it's tractionless! 3.42s with 255/50/16s here
Might be able to find some more power in that 3.4!
Old Feb 12, 2004 | 09:44 AM
FbodTrek's Avatar
Oh, I wasn't
I wasn't "nailing it".....It was pushed down to like 2/3 throttle, I've been a little spooked about gunning it . The motor is pretty close to stock, I got some plans in the work, the only thing affecting its performance now is a lightweight flywheel. Hurry up and build me a turbo Dow!!!! LOL
Old Feb 12, 2004 | 04:04 PM
Car: 91 Camaro
i don't know how you two can spin the tires at 45 or especially 60 mph! i can't do that!
Old Feb 12, 2004 | 04:15 PM
KED85's Avatar
YOUR SWAP LOOKS SENSATIONAL!
You did a superb job!
Here's a pic of 3.4 plug out
Attached Thumbnails Pics of FbodTrek's 3.4-blzng-20bolt-20d-20distb
Old Feb 12, 2004 | 04:26 PM
KED85's Avatar
This is my Blazer carb'd 3.4 conversion.
Yes, this can be done to any year 3rd Gen V6 MPFI OR CARB'D without a problem.
IF ya notice the fuel line, it covers a "dark hole" in cylinder head. See Bottom left corner area, cylinder head, under Black valve cover.
That hole is the location of the Fan Cooling Switch.
The 5/16" blocked recessed plug (it's there when ya buy the 3.4) is removed from this location.
Attached Thumbnails Pics of FbodTrek's 3.4-blzng-20bolts-20c-20dist
Old Feb 12, 2004 | 04:50 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Hey Steven, ask your buddy if he wants to race.
Old Feb 12, 2004 | 05:09 PM
Sonar_un's Avatar
Car: '86 T/A
I'll race him in my Camaro It might be a good match for the L03. lol
however, his car is 3100 lbs... which is.. well friggen light!
Old Feb 12, 2004 | 05:20 PM
br()bert's Avatar
Car: 85 firebird
hey ked, I use the 2.8 manifold also correct? im gathering all the information ahead of time...
Old Feb 12, 2004 | 08:24 PM
FbodTrek's Avatar
Hell no!
I ain't racing Steve in his T/A!!!!!!!!! I agree though, I reckon it would be a pretty even match with the lo3. Hey KED, you got a picture of your 3.4 before it went in, like a "complete" picture? A red block would look AWESOME under the hood..... I finished my wish list for add ons too:
SFC's
AFPR
Strut brace
Ignition Box (mallory, MSD?)
Aluminum Driveshaft (gotta scrounge one up...)
A bottle...
I'd prolly still get stomped by Steves TransDamnnn though....
Old Feb 12, 2004 | 10:13 PM
KED85's Avatar
From the ORIGINAL VEHICLE ENGINE YOU USE
The Induction/Ignition/Timing chain cover-oil pan-water pump-pullies (up to the 1987 year).
Leave on the 3.4 exhaust manifolds as they mate right back to the original vehicle exhaust system.
From the 3.4 you use the 3.4 INJECTORS (replace 2.8 ones in the fuel rail), 3.4 harmonic balancer 3.4 flywheel/flexplate.
DONE!
Pretty much that's what it comes down to.
Do a search for my 2.8->3.4 Long Block Swap Boogie Thread.
Every swap is a CUSTOM swap.
You create the end result by mixing this & that under the hood & no one knows what ya got.
Again don't expect to win every race, but lots more fun trying!
Damn car will pull like a freight train so much torque!
What I parts mixing I suggested is the easiest way to get the swap done & you back on road.
I have camera pictures not digi pic of the 3.4 before I installed. Sorry. I'll check but I really believe no on the request.
Old Feb 15, 2004 | 06:46 PM
FbodTrek's Avatar
More recent pictures
Here's some pictures of my elusive 3.4 beast....
Old Feb 15, 2004 | 07:25 PM
br()bert's Avatar
Car: 85 firebird
NIce paint! I wish mine was a different color. I have that off white color that looks like gm had some moldy old paint left over that they found.
Old Feb 16, 2004 | 10:15 AM
KED85's Avatar
Isn't one of those passenger side headlights slightly out of alignment?
Really you ride looks great!
Now with the powerplant upgrade, bet it's much more fun, too.
Great photo location & usage of camera angles, too!
Old Feb 16, 2004 | 10:59 AM
Dale's Avatar
Engine: 350 S-TPI
looks in great shape for the age!
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
