Something odd with fuel pump....
Old Feb 16, 2004 | 09:18 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Today while cleaning my car, after I moved it onto the driveway and turned it off, I heard my fuel pump continue to run (same sound as when you turn key to on postion). I started the car up again and it fired right away. Turned it off again and heard pump go again. I've listened for this sound before but I don't think it does this all the time. I will be sure to listen for it next time I drive the car and turn it off. Is the pump supposed to continue running after shutting car off? Could my hard start problem be the result of the pump not continuing to run after the car is turned off?
Old Feb 16, 2004 | 09:29 PM
bes217's Avatar
mine does the same exact thing, I think that it might be normal but can't be sure.
Old Feb 17, 2004 | 10:22 AM
sixbanger's Avatar
so, is it supposed to run after turning car off or not? What controls the pump after the car is shut off?
Old Feb 17, 2004 | 12:17 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
it will run for a few seconds after you shut the car off. If you go out an hour later and its still running, you got problems.
Old Feb 17, 2004 | 03:53 PM
sixbanger's Avatar
It continues to run for a bout 4 seconds then shuts off. Problem is that the pump does not do this every time I shut off car.
Old Feb 17, 2004 | 06:40 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Is your Oil Pressure Sender in tact? When mine died, it did this to my fuel pump.
Old Feb 17, 2004 | 06:51 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
its not really a problem mine runs for about 3 seconds after i shut it down so does my friends 89 gta
Old Feb 17, 2004 | 07:10 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Mine does it too once in a while. Hopefully it's not bad.
Old Feb 17, 2004 | 07:23 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
My camaro does it too. If it helps any... I am almost positive the pump turns off consistently at an oil pressure when the car is turned off. Might be coincidence, but maybe the pump turns off when you have less than a certain amount of oil pressure. Thought that was what the fuel pump relay was for... but I dont know. Somewhere around 10psi I think it says when the fuel pump shuts off... thinking off the top of my head.
Mechanical oil pressure gauge. My fuel pump and fuel pump relay are both ~7000 miles old....
Mine doesn't do it when you flip the key on though.... never has. No trouble starting it either. *shrug*
-Bud
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Warlocksirix
Sep 3, 2015 12:26 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
