2.8 not idleing and throtle sticking!
Old Feb 19, 2004 | 11:08 PM
vodavi6346's Avatar
Car: 86 camaro b/coupe
Engine: HEMI! no 2.8 v6
Okay as title reads it won't idle good when COLD and the throtle sticks when i open it up all the way
its off a 86 berlinetta sc 2.8 with 34k
Thanks !
John-
Old Feb 20, 2004 | 12:23 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
wont idle well? high? low? whats it doing? and does the throttle stick at any spot or just WOT? try cleaning out the throttle body, it could be that the throttle plate has carbon build up and causing it to stick. need more info on the idle.
Old Feb 20, 2004 | 01:22 PM
vodavi6346's Avatar
ideling at low when started up when cold .. after it warms up for 2 minutes or drive it down the street it will idel and perform fine its just when its cold ..
Old Feb 20, 2004 | 01:43 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
do you have to actually give it gas to start it when cold? Kinda sounds like the choke isn't working.
mine wouldn't idle when cold once, had to work the pedal to start it and keep it revved up. Was a bad temp sender. But that also set off a code.
I don't know if the IAC or TPS might do that to your idle when cold
possibility i guess
Old Feb 20, 2004 | 02:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
When its cold out side it take a min or so longer for the O2 sensor to get hot enough to work. So the computer goes into loop mode.
Just warm it up with your foot. Hold the RPMs at 2000+ for a min or two.
Mine does that when its cold. It will actually rev up in down while loop mode runs, 1000-1500 up n down, but once warm it runs smooth.
I can't stand that so before I go anywhere, I warm it up myself for a min. I hold the RPMs at 2000-2500 for a min or two and then go about my business. On really really cold days I'll wait till the temp needle moves a hair. So I get heat quicker.
Old Feb 20, 2004 | 10:28 PM
vodavi6346's Avatar
I'm in florida weather latley is around 70's .. lol .. so not that cold .. Thanks guys
Old Feb 20, 2004 | 10:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well be more clear when you give a description.
"Okay as title reads it won't idle good when COLD "
For most of us COLD means COLD, as its winter out.
An O2 sensor still doesn't work till at operating temp, why newer cars have the 3 wire heated O2.
Old Feb 21, 2004 | 12:15 AM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Correct, 02 sensors don't work until after 700F right? Thats "cold".
Old Feb 21, 2004 | 01:32 AM
F585's Avatar
As for the throttle getting stuck make sure the throttle isn't hitting that clamp to your intake hose thingie, you should have seen the look on my face when that happened.
Old Feb 21, 2004 | 11:15 AM
vodavi6346's Avatar
yea i fixed that yestarday .. it was the clamp .. I don't know how i could'nt have seen it but yea .. .... also the O2 sensor .. is that located in the intake tube ?
Old Feb 21, 2004 | 03:05 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
the o2 sensor is in the y pipe , pass side. At least mine is..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 9, 2015 10:01 AM
Randomtask2
Sep 7, 2015 05:06 PM
rjcme
Sep 5, 2015 01:23 PM
