heads?
Old Mar 7, 2004 | 07:20 PM
RedTtop5spd's Avatar
Car: 99 SS
heads?
I know that porting and polishing the heads help quite a bit, but are there any heads that will fit on my 2.8mpfi that give even more performance than porting and polishing the stock heads? Either heads from another stock engine ported and polished, or aftermarket ones? What give the best performance?
Old Mar 7, 2004 | 07:31 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
FWD 6/60 aluminum heads, but then custom headers, the FWD intake, and many other complications.
Old Mar 7, 2004 | 07:32 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
think there is a company out there that was making aluminum 60* six heads, but i can't remember the name. No one on the boards was buying them however, because the price was so high, and no one knew what type of performance gains would be given...if i could only recal who made em. Could alwayz port and polish your lil' iron ones, but i don't know how well the powergain would be....614streets builds some mean lil sixes, might pm him, seeing what he'd recommend....or hopefullyhe'd respond.
Old Mar 7, 2004 | 07:56 PM
Dale's Avatar
Engine: 350 S-TPI
supersix is the company that makes them with 1.8 and 1.5 valves, with porting.
Cough up 6 bills for them.
Old Mar 7, 2004 | 08:02 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Really not that bad
Not that bad of a price. It would be nice to see some dyno pulls on the 3 60* sixes though. Why buy a head that only gives as much gain as headers?
Old Mar 7, 2004 | 08:23 PM
Car: 99 SS
I'm guessing that the common concensus here is that it's not worth buying aftermarket heads and that porting and polishing and doing a valve job on my own is the way to go. Thanks for the input.:hail:
Old Mar 7, 2004 | 08:59 PM
FbodTrek's Avatar
I dunno....
It really depends how much money you have, how much the head job will cost and how much power can be made. 600 dollars is probably about how much a rebuild/port/polish will cost you, (depending on location etc.).
Old Mar 7, 2004 | 10:18 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
someone mentioned new headers to run the aluminum heads...actually they use the same as our irons heads do as far as i can tell. bigger primaries wouldn't hurt with the aluminum heads but i think that they'll bolt up the same.
Old Mar 7, 2004 | 10:43 PM
FbodTrek's Avatar
What about
the intake and accesory bracket holes? Will they match up as well? I know the aluminum heads have smaller combustion chambers. Would be pretty nice to up the compression and lighten up the motor in one pass...
Old Mar 8, 2004 | 04:45 PM
Car: 91 Camaro
yea, i forgot to mention that the acc. mounting holes are different. that would be the biggest problem.
Old Mar 8, 2004 | 07:42 PM
85f-bird's Avatar
Engine: 2.8L, LS1
seems like a quick fix, but since those alluminum heads had a splayed valve design, that also meant that the piston had reliefs cut into it. So in order to change to aluminum heads, we'd also be swaping pistons, so also taking the bottom end apart....wouldn't be a bad idea if you were doing a rebuild, but i would think it'd be a lot of trouble, for decnet (but not incredible) gains....Any other opinions, it's just my .02
Old Mar 8, 2004 | 08:57 PM
Dale's Avatar
Engine: 350 S-TPI
I belive people are installing the FWD heads w/o messing with the bottom end.
Old Mar 8, 2004 | 10:37 PM
Car: 91 Camaro
the FWD motors run dished pistons about the same as ours...they might be the same piston, i'm not 100% sure but i do know that there are no valve reliefs. you'd need a pretty fair amount more valve lift the need reliefs in the pistons...my domed pistons with .512" ex. lift has no problems. do no plan to switch to the aluminum heads if you plan to get a Vortex Performance turbo kit when they come out. well, let me re-phrase that...you might end up with too much compression with your stock pistons and the Al. heads to be able to run more than 7 or 8 psi of boost without detonation. check with doward though...he's done the math on it.
Old Mar 8, 2004 | 10:50 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
the aluminum headed motors run a much bugger dished piston. my ported iron heads with stock valves flow as much as the early 3100 heads. so there is hope for the iron heads. i have seen a big difference though on just how the valve job is done.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
