Is This Rare???
Old Mar 16, 2004 | 08:33 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
Is This Rare???
I have an 82 v6 automatic I pulled the wheels off the other day and found aluminum drums!!! Isn't this kinda rare for a v6 car with an open rear???
Old Mar 16, 2004 | 08:37 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Neat
Didn't know there was such a thing....I want some
Old Mar 16, 2004 | 08:46 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have known about it for years, but thought they only came on z's.
Old Mar 16, 2004 | 08:58 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
It's only rare if you can prove your car came from the factory with them. Even then, I doubt it would be a big selling point.
Old Mar 16, 2004 | 09:28 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I remember Tom p posting something about them when i did a search about something before., I dont think they came on your car, someone probably put them on.
Old Mar 17, 2004 | 03:25 PM
KED85's Avatar
Yeah & no
When the "factory" runs out of a "part" factory "tends" to just ship, "what else fits" until supplier catches up again.
Or yep, definetly a swapped item from wrecking yard donor.
Old Mar 17, 2004 | 06:09 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
check out how much those puppies cost to replace
Old Mar 17, 2004 | 08:33 PM
maroguy1's Avatar
How much are they??? New or used
Old Mar 18, 2004 | 10:51 AM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
I dont even know if you can buy them. I got a set at a junkyard, a good find, for $6 a piece. I think they only came on irocs
Old Mar 18, 2004 | 11:15 AM
Engine: 5.7 / 7.4
I cainat even find a price now, all the parts stores asy new cast iron drum to replace OEM Aluminum. Just think of teh weight savings/less rotaional mass though.
Old Mar 18, 2004 | 11:43 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Its only rare if you think it is
Old Mar 18, 2004 | 04:09 PM
maroguy1's Avatar
What are these used aluminum drums worth??
Old Mar 18, 2004 | 05:57 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
however much you can sucker someone into paying The harsh reality is that the vast majority of used parts aren't worth that much, unless ....
the car is very new, and finding one is a million : one odds (ls1 cars in bone yards w/ full interior (better be leather) and has a six speed.... rare find - worth $$
The car is very old, and finding one is a million : one odds. (1969 Hemi powered Dodge Charger, Fully together yet wasting away, and all those damned numbers are still matching)
So basically, it's only worth what people are willing to pay, and the vast majority of people would much rather waste the $$ on a disc brake setup for the back, than to dump it into a set of alluminum drums. As streetrodder's magazine add always says (These drums are the poor man's discs) doesn't give much room for demanding a high $$ price.
Old Mar 18, 2004 | 06:01 PM
85f-bird's Avatar
Engine: 2.8L, LS1
to help you out a lil more, i was on ebay and saw some aluminum drums off a datsun 240Z, they're brand new drums, however are only going for 25 bux right now, w/o reserve being met....the reserve is at 95 bux. I wouldn't expect some from a camaro to be worth more, most likely less
Old Mar 18, 2004 | 09:38 PM
maroguy1's Avatar
Yah but paying 50$ for a set of aluminum drums is still alot cheaper than putting on rear discs. Just wondering because I am going to swap them for a set of iron drums and dump the car. I have 2 other projects that need my attention.
Linson
Oct 24, 2025 02:00 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Lbibb
May 5, 2016 12:00 AM
okfoz
Oct 13, 2015 02:19 PM
sjorgens
Oct 1, 2015 07:54 PM
