Whats a good head/cam combo for the 3.1?
Old Mar 25, 2004 | 12:57 PM
92RSSlowmaro's Avatar
Any ideas? I know Crane makes some aftermarket cams for our motors, but I have no idea where to find a suitable set of cylinder heads.
Old Mar 25, 2004 | 01:07 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
There are no aftermarket heads for our cars. The best you will find, is a set of pre-ported heads - www.supersixmotorsports.com
The best flowing 60º heads are the 3400 heads, off the late model FWD blocks - but custom brackets, intake, and use of FWD pistons will be needed to use those heads.
Old Mar 25, 2004 | 01:11 PM
Doward's Avatar
Oh yeah... go with the 2030 cam, or if you want to save a couple of bucks, head to Autozone and order the Melling MTC-5 cam kit.
Replace your valve springs, though, with a cam of that size. Then, get a catback exhaust. The exhaust is the biggest kink in our cars!
Old Mar 25, 2004 | 01:43 PM
Thanks for the info.
I think i'll start with exhaust first, actually. Who makes a good cat back system for this engine, and will it need any alteration to fit?
Then after exhaust, cam and heads will follow.
You know.. just so it can breathe better.
Old Mar 25, 2004 | 01:54 PM
RedTtop5spd's Avatar
Car: 99 SS
A lot of people like the Dynomax catback systems.
Old Mar 25, 2004 | 02:17 PM
Yet another question:
Is it worth my while to go with a dual exhaust application on this motor? And does such a kit exist?
Old Mar 25, 2004 | 02:46 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Doward,
You really think that the exhuast is that restrictive? I have intensions of doing my own wye pipe to the stock cat location, what are your views? So it'll be dual 2.5" to a 3" ish.
Old Mar 25, 2004 | 03:59 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
The 2030 cam used in an auto trans application may, no, WILL benefit from a 2200 stall converter to get best results out of it.
Eric
Old Mar 25, 2004 | 04:10 PM
Doward's Avatar
Actually, dual 2" into a 2.5" (mandrel bent, of course) would be more than sufficient.
The exhaust manifolds are the biggest restriction. The last cylinder on each side actually has to fight the other two to dump it's exhaust charge!
Old Mar 25, 2004 | 07:01 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
In other words^
Can you say "hedders"??? We all need them, we all want them
Old Mar 25, 2004 | 08:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: In other words^
I have a crazy feeling that anyone with a welder and a hack saw could take some 305 / 350 $75 headers, cut the flanges into pieces, lose one pipe, bend them around and it would fit.
Old Mar 25, 2004 | 08:39 PM
FbodTrek's Avatar
Would but...
I belive it's a different bolt pattern, that and it would be a pain.... lol.
Old Mar 25, 2004 | 10:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Would but...
Why you need a welder and some tools. Once the flanges are cut so each pipe has it own piece. You weld the old holes in and then drill new ones once you have the pipes bent around where needed. Even if it had the same bolt pattern it would not line up after you tweaked things.
Not really hard just a little fab work and a little imagination.
But for me really my 3rd gen is my econo car. I have a Buick 350 for speed. Never sure if I would ever get headers but I would most likely go the cheap route first.
[The little 350 Buick that could. 450 horsepower at 5400 rpm.
441 torque at 4300, 446 at 5000 rpm and is still over 400 at peak HP. And the new TA aluminum heads and intake are not even ready yet, still stock iron parts. ]
Old Mar 25, 2004 | 10:53 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Re: In other words^
primaries would be a little large unless you've got one healthy v6. you would really have to butcher up a set of v8 headers to make them fit a 60* v6. also, what about the collectors? 3 primaries going into a 4 primary collector....?
Old Mar 26, 2004 | 11:42 AM
So is exhaust a moot point unless I have headers?
Old Mar 26, 2004 | 05:43 PM
Doward's Avatar
No - a cat back is a GREAT start to a new exhaust setup!
Old Mar 27, 2004 | 07:34 AM
KED85's Avatar
Contact fgerle@pacesetterexhaust.com for this product.
It's street legal.
Heads, it's wisest to start with a 3.4 head as the valve spring pocket is larger than on the 2.8/3.1.
YET, there are better springs available for the 2.8/3.1 heads, too.
Dale recently upgraded his 3.4 heads with all new goodies (Crane parts & a 3 angle valve job).
I'd say go with the lowest milage used long block 3.4 ya can find. It already is beefed up with all the goodies ya seek. That factory issued 3.4 RWD mill uses the Crane 2030 cam. Add headers & frame suspension upgrades & have some fun! Don't forget to add ignition system upgrades, too.
Attached Thumbnails Whats a good head/cam combo for the 3.1?-v6-20st-20legal-20header.jpg
customblackbird
Aug 15, 2021 10:16 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
theurge
Aug 21, 2015 12:46 PM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
