No power at WOT
Old Mar 25, 2004 | 01:32 PM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
No power at WOT
What would cuase a no power bog down at WOT on an '87 MPFI 2.8? Part throttle is fine and I can gradually get the speed up. But it wont do jack when floored.
Old Mar 25, 2004 | 02:05 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
its a 2.8, u need a modern engine for that. If u are going like 3 mph and mash it to the floor, of curse it will bog down, if ur going like 10 and mash it then it will go.
Old Mar 25, 2004 | 02:07 PM
92RSSlowmaro's Avatar
If it were me i'd have my TPS tested first, then go from there.
Old Mar 25, 2004 | 02:11 PM
CHVYPWR's Avatar
Being a 2.8 isn't the problem . Not only will it bog down, but it won't build speed either at wot. Something with the system isn't working right.
Old Mar 25, 2004 | 02:13 PM
Engine: 2.8 Lt
Transmission: 5 Spd
O i see. Yeah take a look at the TPS and clean the TB out. Could be full of carbon. Hows it run besides at WOT?
Old Mar 25, 2004 | 03:01 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Check your fuel pressure too. A dying pump can cause WOT issues.
Old Mar 25, 2004 | 04:11 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Weak ignition, too..
Old Mar 25, 2004 | 04:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
...which goes along with incorrect ignition timing... is the inside of the dist cap gunked up with carbon tracking?
Old Mar 25, 2004 | 05:52 PM
CHVYPWR's Avatar
In park, it's very snappy and responsive. And once it makes it up to speed, it runs fine. It's getting up to speed that the problem occurs.
Old Mar 25, 2004 | 05:56 PM
CHVYPWR's Avatar
It doesn't feel like a miss-fire issue.
Would not having the VSS hooked up do this?
Old Mar 25, 2004 | 06:05 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
No, the VSS should not cause that.
As far as I know, the VSS has no bearing on how the computer controls the engine (other than cutting it off at the speed limiter setting).
Old Mar 25, 2004 | 06:40 PM
Doward's Avatar
2.8, maf, right? Go rap on the MAF with the handle of a screwdriver while idling - see if it stumbles.
Old Mar 25, 2004 | 06:44 PM
CHVYPWR's Avatar
I have a spare maf, i'll swap it out and see.
Old Mar 25, 2004 | 06:58 PM
Doward's Avatar
Rap on it, first.. if it stumbles, it's bad. You can test 'em both, tho!
Old Mar 25, 2004 | 08:06 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Mine is bad on my car and have to wait on money to replace it, but hitting it does not always work. Only sometimes. Exchnage it to make sure
Old Mar 27, 2004 | 10:51 AM
CHVYPWR's Avatar
Thanks for the tips, I'll give a try on these and check back with what I find.
Old Apr 16, 2004 | 12:44 AM
CHVYPWR's Avatar
Problem solved. The stock fuel line for the carb'd 2.8 was too small to support the needs of the injection
Old Apr 16, 2004 | 05:30 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
There ya go. Someone should write that down n save it. If you go from carbed to FI you need to run a larger feed line.
Slush92RS
Sep 2, 2015 08:56 PM
sailtexas186548
Aug 24, 2015 10:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
