2.8 Injectors: Ford SVO v/s Fiero ADS?.
Old Apr 14, 2004 | 08:09 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
I think the most common injectors upgrades for 2.8, 3.1 & 3.4 V6s are the Ford SVO 19 lbs/hr (O.K.?). But, what about the "ADS super injectors" for Pontiac Fiero V6?.
Anny comments will be appreciated. Thanks in advance,
Denis V.
Old Apr 14, 2004 | 09:36 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Why are you upgrading the 2.8 injectors anyway? They don't go static on me until about 5 psi @ 5000 rpm... I seriously doubt you're pushing their limits... at any rate, I recognize SVO as the superior of the two, having no information or known feedback on the ADS injectors.
Old Apr 14, 2004 | 11:57 AM
Denis.V's Avatar
Axle/Gears: No idea
Well, I only wish know if an injector upgrade is a common "good idea" for more power in any V6. If not, they can remains the same.
Thanks,
Old Apr 14, 2004 | 12:40 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
Ford mustangs also use 19lb injectors.
Old Apr 15, 2004 | 03:22 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Upgrading fuel injectors only results in a performance gain when the existing fuel injectors are simply incapable of supplying the neccessary amount of fuel to the motor... you'd need a 2.8 capable of spinning to at least 6500 rpm, or a turbo or supercharger, to start concerning yourself too much
Old Apr 15, 2004 | 08:52 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
well new ones would be alot cleaner and have better spray pattern/atomization that old ones.
Old Apr 15, 2004 | 10:20 AM
TechSmurf's Avatar
Engine: LS1, Scrap
That is a question of maintainence, not performance modification.. do you consider changing your spark plugs a performance modification too?
Old Apr 15, 2004 | 11:04 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
We'll see... I've got a set of 6 Iridium plugs waiting to go in.
Ed1LE
Sep 30, 2018 09:14 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
usafirebird
Sep 29, 2015 11:58 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
