here are the pix
Old Apr 14, 2004 | 07:51 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
here are the pix
i am inserting the pix for the parts that i need to find where to put back on my car also i need to know how to make my plenun shine or maybe how to paint it
Old Apr 14, 2004 | 08:08 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
what do i do with this.Do i get it painted or polished?
Old Apr 14, 2004 | 08:35 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
one on the left goes to the alternator. Other end I think goes around belt tensioner or something. The "L" on it shields/lays against radiator hose.
One on right I'm not sure
Painted or polished is up to you. Dupli color makes a good "aluminum" color that when misted on is very hard to tell difference
Old Apr 14, 2004 | 08:39 PM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
Media blast...
I'd say Media Blast that upper plenum... and shoot w/ Clear high-temp heat paint... for that oh-so shiny aluminum look !
Can't help ya' w/ the brackets/pieces parts.
Old Apr 14, 2004 | 08:52 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Im with Dale
He's right about the brackets (I also have no friggin clue about the other one). As for the plenum, You can't go wrong painting it to match the car (unless you have a white car, ewww). Polising is a long process, you could better spend the time porting. Check out my link, I painted mine, it turned out pretty good.
Old Apr 14, 2004 | 09:18 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
i'll figure out later about to painting or media blast.I don't know who does media around here and how much is going to cost.About the piece on the right i know was attached on one of those valve cover bolts
Old Apr 15, 2004 | 01:33 AM
RedTtop5spd's Avatar
Car: 99 SS
I'm working off a tired memory right now...3ish in the morning? But I think that the one on the right is for either the egr or else the coil. Could be wrong, been stuck working with a single cylinder engine for the past 11 hours.
Old Apr 15, 2004 | 06:43 AM
Dale's Avatar
Engine: 350 S-TPI
left, see attachment.
After thinking, the bracket on the right looks VERY smiler to that on a 3.4 that holds the purge canister control valve to the intake.
Old Apr 15, 2004 | 08:33 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
it's saved on file.tkx very muxy.Now i have to wait for the injectors to arrive from the cleaning guy.(sorry forgott the company name but the guy is called rich)
Old Apr 15, 2004 | 08:44 PM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
I believe I may know what the bracket on the right is but the
photo is throwing me off a bit if I'm mistaken. It is used to mount
or brace the 2 vacuum lines coming from the TB/smog set up that
get connected over to the purge cannistor. The bracket is
mounted onto the drivers side valve cover. Note the attached photo:
Old Apr 15, 2004 | 08:50 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
good pix x55cam that's the one now i have to wait for the injectors from cruzinperformance
Old Apr 15, 2004 | 09:59 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
for the plenum, you could have it ceramic coated...contact me for details.
Old Apr 15, 2004 | 11:38 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I once tried to polish my plenum, for about 2 minutes! That is alot of work! I ended up painting it with VHT engine paint.
Old Apr 16, 2004 | 08:29 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
the one thing i am not into is polishing,man i hate it
I mighty found someone to do a sand blasting on my plenun,i'll have an answer on monday.....:lala:
1MeanZ
Dec 18, 2015 05:39 AM
okfoz
Oct 13, 2015 02:19 PM
Mohammed
Apr 23, 2002 05:35 AM
Mohammed
Apr 18, 2002 07:51 PM
