Engine Specs
Old May 2, 2004 | 09:50 PM
92RSSlowmaro's Avatar
Engine Specs
Other than a shop manual, where can I find detailed specs for the 3.1? I need things like head flow, cam specs, valve specs, etc etc.
Much appreciated!
Old May 2, 2004 | 10:00 PM
oil pan 4's Avatar
Car: 89 Firebird
I have never seen flow #'s for out heads. They do have 85cc intake ports and 60cc exhaust ports.
The valve sizes are 1.43 and 1.72.
The cam and valve train sucks the stock cam is only going to make about .4'' of lifton the intake and .42'' on the exhaust.
The stock valves and springs are only good for .440'' of lift no more.
Theres more on my cardomain site.
Old May 2, 2004 | 11:17 PM
Thats a start, thank you much
Old May 3, 2004 | 02:27 PM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
Here are the flow numbers - pre & post porting/polishing:
http://users.spec.net/home/emxjc/flow_bench.html
Old May 3, 2004 | 02:48 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
3.1 = 3.50 bore x 3.310 stroke
cam=140hp/4400rpm and 180tq/3600 rpm
dur196/203, lift .394/.410, lobe sep is 109
valve size is 1.42 and 1.72
Old May 3, 2004 | 05:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is there any way to do a homemade flow bench? I know it could never be accurate... but I wonder about something that you could do, to actually say "yes, I made an improvement". Know what I mean?
Old May 3, 2004 | 07:54 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
they have flowbench kits out there that are fairly accurate. You also need a shopvac with a good amount of airflow.
Old May 3, 2004 | 10:00 PM
Thanks all for the feedback!
Old May 3, 2004 | 10:31 PM
RedTtop5spd's Avatar
Car: 99 SS
Know where someone might be able to find one of them?
Old May 4, 2004 | 04:08 AM
oil pan 4's Avatar
Car: 89 Firebird
If you want a flow bench
Go to MSN.com and search "flow bench" and the in the first few hits there will be plans for a MSD designed home made flow bench.
Old May 4, 2004 | 04:14 AM
oil pan 4's Avatar
Car: 89 Firebird
If you look at the V6 heads flow #'s you will see why our engines suck.
I all ways said the exhaust flowed good and that the intake didn't.
The exhaust flows all most as good as the intake.
Old May 4, 2004 | 06:51 AM
Car: 99 SS
Re: If you want a flow bench
Hey thanks for that info. I did a search through yahoo and found nothing useful.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Electro_X
Aug 19, 2015 07:59 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
