Question for the pro's
Old May 12, 2004 | 09:01 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
I got code 34 on my car(maf)did everything to fix that even changed the maf,but still the same.
I got my chilton's book and decided to check it out.i got the part that says "connect test light between harness connector terminals "a " and " c " i got the lights on and the book says falty maf sensor connection or sensor.
It doesn't say how to fix it.Anyone has any idea how can i fix it?
Old May 12, 2004 | 09:05 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Make sure the wires in the pigtail aren't crossing. You've prolly got a wiring problem.
Old May 13, 2004 | 05:49 PM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Yes, get a dmm (digital multimeter) and check for continuity between terminal 'a' and 'c' with the connector unplugged from the sensor. Also, check the terminals for any signs of corrosion. I don't think thats the problem since I believe that 34 is for too high of signal detected from the MAF. But I could be wrong there, I know there is one code for too high of a signal and another for too low of a signal (codes 33 and 34). Too high I would look for a short and too low I would look for increased resistance (ie corrosion, damaged wire, damaged terminals in connector at MAF or ECM).
Old May 13, 2004 | 06:04 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
I checked everything today but found nothing wrong i even changed the relay but still the same.I had a code 33 before but i replacd the maf and now with the new one i got code 34.my chilton's book tell me toput a light text on terminal "A" and ground if the light goes on i have to check the connection so i folowed the wire and found the relay everything was good.Now i am out of ideas
Old May 13, 2004 | 07:00 PM
Engine: 3.4L 207 V6
Do you have the old MAF? If so, plug it back in and see if it resets the old code. If it does, I would say that the new one you got is either defective or not the right one for your car. Also, did you use a K&N filter on the car? If oil from the filter (or any other dirt or debris) covers the sensor in the MAF, that would generate a low signal.
Old May 13, 2004 | 08:42 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Not the one for my car makes sense.The format of this one is diferent then the old one, i took the old one to az and they told me is the right one but something seens different here.I'll check with then tomorrow again
Old May 15, 2004 | 08:26 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
So i got the right one but still the same code even if i change to the old one.I was wondering if you guys can check one thing for me.I diconected the relay near the battery and found that a brown wire has power all the time the other wire that has power is the pink/blk one but only with the ignition on.Is that right for yours cars.If not i have to check the wire from the front after the relay all the way to the back.
By the way i heard that maf has two relays.I found one near to the battery but the other i can't find.I found three on the left side of the car near to the power brakes but i don't know with one is?
Old May 15, 2004 | 11:25 AM
Engine: 3.4L 207 V6
Only MAFs with a burn off circuit will have two relays. The burn off circuit was used in V8 cars as far as I know. The relays by your brake booster are for the fan, fuel pump and a/c. Your question about power to the wires is fine. As long as you have power to the brown and pink/black when the vehicle is running, you will be fine. So now you have the same code regardless of which MAF is plugged in? If so, check ALL connections and wires.
Old May 16, 2004 | 06:37 AM
IROC57TPI's Avatar
Get a new MAF relay... they're only less than $10 and I bet thats whats causing your problem..
Old May 16, 2004 | 07:47 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
i checked all the wires and found nothing wrong,check the volts on terminal "b" and got 5v.So i think something else is triggiring the code 34.I'll check all the wires on the car,i know something is wrong because my cooling fan has a bypass on it near the relay the yesterday i changed the small sensor under the tb(hope the fan is going to start on auto mode today.
it has a new relay.
Old May 16, 2004 | 04:02 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Nope.. thermal switch for the cooling fan is in the back corner of the passenger side cylinder head.
Old May 16, 2004 | 07:16 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Damn another one to change ahhhhhh the car that i just got is already hurting my wallet...
By the way code 34 is now gone finally.just changed the relay so damn duno now got cod 32 belive is the egr but the car is getting so hot that i almost got my feet tosted.is it normal to run on 220 or above?
Old May 16, 2004 | 07:21 PM
Engine: 3.4L 207 V6
No, that's too hot. You may want to verify that your cooling fan is working.
Old May 16, 2004 | 07:24 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
as i told before it works all the time with the ignition on
i guess my car doesn't have that thing (i forgot the name)underneath it to help the cooling sistem or to make the air getting to the radiator
(air dam i think it's the name)
Old May 16, 2004 | 08:06 PM
Engine: 3.4L 207 V6
Did it run not before you had these electrical problems? I must have missed the part about it running all of the time, I don't see it in the post. But anyways, not having the air dam will have the same effect. Especially in stop and go traffic.
Old May 17, 2004 | 04:50 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
the bypass is there since i got the car so i changed the relay and the little sensor underneath the tb and it did run on by itself so tonight i'll check the other piece berind the motor on the right side as said by techsmurf so i let you now tonight
Old May 17, 2004 | 07:25 AM
Engine: 3.4L 207 V6
That little sensor under the TB will either be the temp sensor for the telltale (instrument panel) or for the ecm.
Old May 17, 2004 | 02:15 PM
TechSmurf's Avatar
Engine: LS1, Scrap
It's for the ECM. The gauge sending unit is on the front corner of the drivers side cylinder head.
Old May 17, 2004 | 06:53 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
techsmurf i went to the car today looking for the termal switch u told me about and found nothing there.I know for sure that i have one on left front corner of the cylinder head and i have two underneth of the tb one next to each other but one is small and the other is bigger and got a pigtail that looks likes those for the injectors. So my question is "This one could be the thermal switch that are u talking about or it's the could start switch?
Old May 17, 2004 | 07:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
TechSmurf is right; that sensor's gotta be back there. You might have to move a ton of crap to see it, though. Should have a single green wire coming from it... or is that purple? Shoot, can't remember. But yeah, it's at the rear, outermost corner of the passengerside head.
As for the two you're seeing under the TB, yes, one is the cold start switch; the other is the CTS (coolant temp sensor).
Old May 17, 2004 | 07:45 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
i think i have seen a single purple wire somewhere there i'll check again and remove evething on my wayto that switch,because i don't want my fan with a bpass and running all the time and the chilton's dont say nothing about it.By the way do you know where can i get one of those air deflectors my car doesn't have one
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
