question about curbs(lol)
Old May 31, 2004 | 08:26 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
OK My question is when i drive my car and turn or make a u-turn looks like i am going over the curbs(note that i said curbs)the front of the car goes crazy, it goes up and down like a carrousell.Anyone knows what is going on?
Old May 31, 2004 | 10:10 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
you mean the front of the car bounces when you try to surn sharp?
Old May 31, 2004 | 10:24 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ball joints? but these cars have struts??? hmmm
I had a 79 Duster that did that and it was a worn out upper ball. When your turned sharp it poped in and out.
Had a 68 Ford that would click n pop real bad when you turned sharp, never found out what it was and traded it for a 9sec drag bike.
My Firebird doesn't have any problem like that but I notice our cars are able to over steer. You can turn the wheel beyond any realistic turning radius and the tires just skip n hop when you turn around.
I wonder if maybe your feeling that but worse from some lose suspension parts?
I seriously think I / we[the board] need to come up with a steering stop of sorts. If you over steered at speed the results would be worse.
Old May 31, 2004 | 10:39 PM
Car: IROC Z
Engine: 5.7
like a pitchpole?
Old Jun 1, 2004 | 04:57 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
yes just like that.
Old Jun 1, 2004 | 06:53 AM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
how wide are your front tires? it may be that they are hitting the framerails and lifting up the front end, my car does this pretty bad i have to discipline myself no to turn too far, no u-turns for me.
Old Jun 1, 2004 | 08:29 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I would say it is the sidewall of the tire flexing, and the bottom loosing some grip
Old Jun 1, 2004 | 10:04 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree w/Dale; instead of U-turns, make a K-turn. (Besides, a K-turn is legal- at least in NJ, U-turns are illegal). Might as well have an alignment done if it's been a while.
Like 2.73's said, the front tires' sidewalls can rub the inner fender; there's no "fix" for that, it's normal.
Old Jun 1, 2004 | 07:18 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
ok the tire size is p275/65/15 and it's not hitting the side wall because there's no marks on the tire or inside the fender however the outside edges of both tires are worn out.Any sugestion?
Old Jun 1, 2004 | 07:38 PM
Dale's Avatar
Engine: 350 S-TPI
alighnment out, or something worn so that your alignment cant be corrected.
When was last time for alignment?
Check all your wheelbearings, ball joints, etc.
Find empty parkinglot, have someone else try to duplicate problem while you watch, vise/versa.
It still could be the tire rolling over.
Old Jun 1, 2004 | 07:53 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Again, I agree. I'm agreeable today. I have P225/60r15's on the front, before that, I had P215/65r15's on the front- and I've always had this bounce thing at full lock- even after rebuilding the whole suspension, and even after millions of alignments.
Just do a K-turn instead.
Wait- P275/65r15's aren't rubbing the inner fender? Wow.
Oh and as for the outer sidewall being worn; that happens with our cars, nothing you can do about it- it's b/c of the suspension design. It's a good way to knock a few bucks off of a used f-body, though ("And look at those tires! I need to buy new ones and get an alignment; take $200 off and you've got a deal")
Old Jun 1, 2004 | 07:59 PM
Engine: hamsters
LOL, so true. "Geez, that front end must need a lot of work, damn."
Old Jun 1, 2004 | 08:13 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
not 275 it's 215. So about the tire rolling over what can i do to correct that? And the car since i got last april never relly did not to it .I'll thake the front brakes down this weekend and change the pads and rotor.While there i'll take a look for something worn out.About the bearings doesn't feel that but anyway i will check
Old Jun 2, 2004 | 03:31 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
what is a k turn?
Old Jun 2, 2004 | 10:10 AM
92RSSlowmaro's Avatar
A bad ball joint wont cause this problem, unless its shot to the point where it creates so much camber roll, that the tire is practically riding on the sidewall. As for inner fender well scrapeage, the stock 215's have tons of clearance, so I dont see how that would be it.
Also, I thought our wheel bearings werent serviceable?
Old Jun 2, 2004 | 10:36 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
they're definately serviceable, you can get to them upon removing the brake rotor.
Old Jun 2, 2004 | 10:44 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Originally posted by Xophertony
what is a k turn?
Lol...K-turn = Instead of trying a U-turn to go 180...this is assuming you're at a T road or a 4 way, let's say make a left onto the perpendicular road. Then put it in reverse to back up past the street you were on, then drive back left again so you're now going the opposite direction you were coming. Go over the path of travel in your mind and it'll make a 'K'....
Old Jun 2, 2004 | 12:11 PM
Engine: hamsters
I have to end up doing an Austin Powers K turn, my turning raduis is so bad.
Old Jun 2, 2004 | 12:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
and this is suppost to be safer then a U turn?
Old Jun 2, 2004 | 12:35 PM
Dale's Avatar
Engine: 350 S-TPI
Thats what I'm thinking, sounds worse
Old Jun 2, 2004 | 02:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, there can't be other cars on the road!
What do you guys do when you need to change direction on a skinny street? Drive over someone's lawn?
I've never done K-turns like Nixon1 described tho, I don't pull into a side street. I just do 'em on the road. Hey this was the quickest pic I ever drew, took me under a minute! I can nail this pretty damn fast- and that's without slamming the trans around.
Hey- wait- you guys are scaring me, this is basic driving 101, isn't it??
Old Jun 2, 2004 | 02:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
umm. i just, you know, turn around.
as long as there is two lanes worth of road, you have enough room.
athough what you described, is fine.... athough thats just your regular 3 point turn.
and yes. i have driven over peoples lawns. want to play basketball in the street and not move? fine. i'll go play in the yard.
Old Jun 2, 2004 | 02:46 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
BTW, here is how I turn around
:lala:
Old Jun 2, 2004 | 03:27 PM
Dale's Avatar
Engine: 350 S-TPI
I turn around by slamming the break, jurk the wheel and punch the gas at the same time
Yes, I have went thru peoples yards too
Old Jun 2, 2004 | 08:17 PM
Nixon1's Avatar
Nice vid. I used to do that, but the problem now is my rear tires are very grippy and the fronts are very slidy. So I hit the gas, the car pushes forward and understeers, then the front tires slide. Imagine hydroplaning.....on a dry surface....at 5 mph.
Oh and Tom, I only described the K-turn in reference to a 4-way or T junction because those are the only instances where I see a U-turn being plausible...I was comparing. Lol....I do the good old 3-pointer all the time, although I usually try to find a driveway. An empty driveway.
Old Jun 2, 2004 | 08:19 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
dont worry just try to avoid u-turns, i hate doing u turns in my car, especially when the street is wet, my tires tend to slip when i have my wheel cut all the way and end up going straight rather then turning , you want to do simple u turns get a honda civic
Scamo-2.8
May 20, 2016 07:01 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
